Belkin Lan USB HUB
Forum about Domotica related gadget like Pocketpc, UMPC, Smartphones, Ipad Etc
Moderator: TANE
Belkin Lan USB HUB
Postby Francois » Fri Nov 14, 2008 5:42 pm
Just one tip, today I joined my Homeseer server to my Small Business Server 2008 Domain and suddenly the USB hub stopped working!
Cause: a group policy that switches on the Windows XP firewall.
Solution: create an exception for both UDP as TCP on the port used by Belkin, refer to the help file for details section "firewall"
Good luck!
Francois
Francois
Belkin Lan USB HUB
Postby Digit » Fri Nov 21, 2008 11:51 pm
The Belkin LAN USB hub doesn't work for virtual machines on MS Windows Server 2008 with Hyper-V role. The Belkin Control Center software won't install on VM's with server OS's (w2k3 x64, w2k), this was expected. The Belkin CC does install on XP Pro SP3. It does recognize the USB devices, but driver install fails and from the Device Manager it shows code 39 (corrupted or missing driver).
I tested this with 2 different USB memory sticks and a USB camera.
Belkin Lan USB HUB
Postby TANE » Fri Nov 21, 2008 11:56 pm
Robert,
I have tested with Vmware machines...all did work fine..even the Vmware machines running on my Imac
It will not install on a server...for this you have no other options than USBanywhere.
Belkin Lan USB HUB
Postby Bwired » Fri Nov 21, 2008 11:57 pm
Same for the Icy Box
http://www.komplett.nl/k/ki.aspx?sku=391086
Only drivers for XP or Vista. So no use for me, next time i need to be more careful!
Belkin Lan USB HUB
Postby Digit » Sat Nov 22, 2008 12:12 am
Same here [:)]
And USB support for Hyper-V doesn't seem to be high prio for MS, so i'll have to find another solution.
My thoughts 'this is to good to be true' as mentioned in an earlier post in this topic, become true after all. I hoped i was wrong..[:(]
Belkin Lan USB HUB
Postby Bastiaan » Sat Nov 22, 2008 12:36 am
There will be no USB support for HyperV. But for me it worked inside the VM's when they were running WinXP. I had no driver problems there.
Bastiaan
Bastiaan
Belkin Lan USB HUB
Postby Digit » Sat Nov 22, 2008 1:23 am
Strange...
Any hints, tips? I don't like having things running on the host, the Belkin was the major trigger for me to create a XP VM, expecting that to work where all other VMs failed to.[:(]
Belkin Lan USB HUB
Postby DJF3 » Thu Dec 25, 2008 11:58 am
bWired,
So you tested the Icy Box that only has XP/Vista drivers.
My VMWare server (host) is XP. After installing the drivers onto XP, do you think I would be able to use the USB ports in a Win2k virtual machine running on that XP host?
2nd question: Does the Belkin box have the same problem?
DJ
DJF3
Belkin Lan USB HUB
Postby Bwired » Thu Dec 25, 2008 12:27 pm
Hi DJ,
I think this will work like Digits Belkin
I can send you you the box if you want, you try it out, if it works you can pay me 40 euro :-)
The thing is brand new.
Belkin Lan USB HUB
Postby Digit » Thu Dec 25, 2008 1:32 pm
Installing drivers on the host will not help for the VM.
Regarding the Belkin: IIRC the Belkin software doesn't like Server OS's like Win2k. So your VM should be XP i guess. Also read topic.asp?TOPIC_ID=1890 with my latest findings regarding the Belkin.
Belkin Lan USB HUB
Postby Digit » Thu Dec 25, 2008 1:34 pm
PS. I am talking about Hyper-V, not VMWare, so there may be differences since some VMWare has better USB support.
Belkin Lan USB HUB
Postby jruys » Wed Jan 14, 2009 9:49 am
I've got it working on Win2K3 server, though the Belkin driver indeed doesn't work.
After looking at the .inf files I found the OEM supplier of the chipset used, and they do have a Win2K driver! Go to www.silexeurope.com and look for the drivers for the sx-1000u. The software is scarily similar!
If you prefer the Belkin control center, you can just copy the files off the CD. Once the Silex driver is installed all seems to work well.
I now have this running with my Bluetooth dongle connected remotely to Homeseer's BT plugin. Kewl :-)
/JW
jruys
Belkin Lan USB HUB
Postby DJF3 » Wed Jan 14, 2009 10:21 am
Great tip JW!
I now have my BT dongle connect to the Belkin straight from my Windows 2000 Server Virtual Machine (VMWare server)!
Works like a charm! (now we need a better range for the Asus BT dongle ;-)
Cheers
DJ
DJF3
Belkin Lan USB HUB
Postby DJF3 » Wed Jan 14, 2009 8:14 pm
Note that I installed the silex 3.3 (or 3.1) driver sw and copied the entire belkin sw directory from my other PC. So I'm using the Silex driver and the Belkin Connect sw. This seems to work very stable.
With the Silex connect sw I noticed that it keeps disconnecting my BT dongle every now and then.
DJ
DJF3
Belkin Lan USB HUB
Postby Snelvuur » Wed Mar 25, 2009 11:41 am
btw, a new type has arrived from iogear.. http://www.iogear.com/product/GUIP204/
Snelvuur
PreviousNext
Return to Gadgets Forum
