Door opener
Forum about Domotica related gadget like Pocketpc, UMPC, Smartphones, Ipad Etc
Moderator: TANE
Door opener
Postby AshaiRey » Mon Sep 05, 2011 9:10 am
I saw this project about opening the door with a secret door knock
Re: Door opener
Postby thechad » Fri Jan 31, 2014 5:52 am
I have done this also but using a capacitive touch sensor and an arduino. You need to touch in a defined pattern with a small tolerance between the timing and length of the taps.
I had it opening the garage from outside if i forget my keys. Ran a small rod through the brickwork to the outside for touch sensor...was almost invisible. Worked well.
thechad
Return to Gadgets Forum
cron
