PLCBUS 4809E TTL interface
Forum about PLCBUS devices & software.
Moderator: Digit
Postby Jfn » Thu Jun 05, 2008 2:22 pm
A Visonic alarm system (the PowerMax series) and X10 go hand-in-hand. With the PowerMax and an XM10 interface, you can control up to 15 appliances.
But what if you do not run X10, but have PLCBUS in your house (as I do)? In this case you might be interested in the 4809 TTL interface for PLCBUS. Does for PLCBUS what the XM10 does for X10.
More info: http://www.plcbus.com.cn/4809uk.htm
This interface should become available soon. It saves you the cost of an XM10 interface and an X10<->PLCBUS convertor.
Als het niet gerepareerd kan worden dan is het niet kapot!
Jfn
Return to PLCBUS Forum
cron
