PLC user ( beginner ) expierence
Posted: Tue Jan 20, 2009 11:54 am
Hello ,
Just got my small plc setup for a few weeks now and i wanted to share my expierence.
My 1st impressions is that everything reacts amazingly fast, with in the blink of an eye
My setup contains:
2 PLC2027 Plugin switch
2 PLC2263 Micromodule 1-Lamp (3-wire) PLCBUS
2 PLC2026 Plugin dimmer
1 PLC1141 USB to pc Interface
Homeseer + stippusplugin.
I started with building in the micromodule into the wall, dismounted the original switches to find out that the micro modules were not that micro and did not fit allong the original switches because of the available space. After the needed re wireing for the 3rd wire that was missin things went on smooth. i remembered those old KaKu switches who where a good replacement for the old ones because of the less space they take.
Before mouting the switches i instaled the plugin for homeseer, switched the modules in programming mode by holding the only button on the micro module for a few second, sended a housecode from the plugin to the module to program it and it worked perfectly.
I repeated this for the other modules and it seemed this was going to be a perfect install. Everything worked fine, dimmers reacted fast... and where going gentle up and there it happed.. the light was flashing rapidly like a ghost was invading my HA system. My 1st idea was a loose wire, but after some investigation it seemed like some device that sends codes over the powerline, as it happens every whole hour, and for sure on the halve at 22:30 22:30. Just a second of 10 the light flashes irregular like it recieves data.
After contacting the company that delivered the plc setup they told me that this filter 4816 DIN PLC would probebly solve my trouble as it seems this data comes from outside of my network. I am still wondering about this buy, as it is about the most expensive part of the plc collection and buying 2 zwave dimmers and a interface cost less.
At the end i am still glad with my plc setup and enthousiastic about its reliablity and fast 2way reaction speed.
Until so far my experience with plc.
My setup contains:
