PLC 1141 - Read from Serial
Posted: Sun Sep 12, 2010 12:13 pm
Hi
This is my first post here - I recently started to play around with PLC (1141+ - Serial) and right now I try to develop some C libs to work with the API.
I can send commands to the PLC and everything works fine but I also want to receive answers and here is where I got stuck.
When I open the device I can easily send commands - BUT when I try to read I don't get any answer (despite the ACK bit is set).
I am pretty sure my serial settings are wrong - so I assume the correct settings are those:
9600 BAUD
8N1
Canonical (meaning line-based - no need to process every byte)
Syncronous (so no Signal Handler is needed - answer will be sent right after command).
Here is what I am doing:
Open Serial at the beginning of the programm
read and write functions
and here is the main code where I send some data to PLC and don't get any answer:
Reaction is - the Light turns on and the stdout says:
Since I am playing around for a few days now without any clue how to solve this it would be really great if somebody has any ides
Bye,
yammi
9600 BAUD
8N1
struct termios tio;
memset(&tio,0,sizeof(tio));
tio.c_iflag=0;
tio.c_oflag=0;
tio.c_cflag = CS8|CREAD|CLOCAL; //8n1,
tio.c_lflag=0;
tio.c_lflag |= ICANON;
*fd = open(SERIAL_DEVICE, O_RDWR | O_NOCTTY | O_NONBLOCK | O_SYNC );
cfsetospeed(&tio,BAUDRATE); // Baudrate is B9600
cfsetispeed(&tio,BAUDRATE); // Baudrate is B9600
tcsetattr(*fd,TCSANOW,&tio);
int tty_read (int *fd, char *buffer, int size) {
int ret;
ret = read (*fd, buffer, size);
if (ret < 0) {
if (errno == EAGAIN) {
printf("SERIAL EAGAIN ERROR\n");
strerror(errno));
return 0;
} else {
printf("SERIAL read error %d %s\n", errno,
strerror(errno));
return 0;
if ( ret == 0 ) {
printf ("read returned 0 byte\n");
return 0;
return 1;
int tty_write (int *fd, char *buffer, int size){
int ret;
ret = write (*fd, buffer, size);
return ret;
char buffer[10] = {STX,0x05,0xff,0x00,0x22,0x00,0x00,ETX}; // 0x22 means "ON" and "send ack"
ret = tty_write(&serial_fd, buffer, sizeof(buffer));
usleep(500000); // wait ...
char read_buffer[100];
memset(&read_buffer,0,sizeof(read_buffer));
if ( tty_read(&serial_fd, read_buffer, sizeof(read_buffer)) ) {
if (read_buffer != NULL) {
printf ("got feedback %d\n", sizeof(read_buffer));
hexdump (read_buffer, sizeof(read_buffer)); // let me see it's hex code
} else {
printf ("no feedback\n");
else
printf ( "read failed\n" );
SERIAL EAGAIN ERROR
SERIAL read error 11 Resource temporarily unavailable
read failed
Bye,
yammi
