domotiga 1.0019 pasword hashing not working
Moderator: RDNZL
Postby JohanVanDyck » Sun Dec 21, 2014 11:41 am
Hi
I installed domotiga 1.0019 on my cubieboard (cubian OS). I also installed domotiyii web front-end. Everything update to the latest version.
With the default auser admin and password admin, everything is working fine. However, when I change my password via the domitiga client, I can't login anymore.
I can't login to my domotiga client; I can't login to domotiyii.
When I manually alter the mysql users table with the original hash for admin/admin, everythink is working fine. --> either the users module in domotiga isn't working anymore or a charconversion is going wrong. Does someone has the same behaviour? How to debug?
Some info:
- cubie OS locals: cat /etc/locale.gen gives en_US.UTF-8 UTF-8
- the domotiga.users table in mysql is utf8_general_ci encoded. (but I have same result for latin1 encoding)
- versions on domotiyii:
JSON-RPC server 0.04
PHP 5.4.35-0+deb7u2
Yii framework 1.1.15
Yiistrap 1.3.0
Thanks
Johan.
JohanVanDyck
Re: domotiga 1.0019 pasword hashing not working
Postby emvee » Sun Dec 21, 2014 2:56 pm
Yes, from your description it looks like DomotiYii is not writing the right password hash to the database.
If you want to debug things, have a look at domotiyii/protected/models/Users.php
emvee
Postby uAlex73 » Sun Jan 04, 2015 7:53 pm
The hashing worked a while ago (i had it working in my pre-alpha Yii), but i will have a look why it isn't working anymore.
uAlex73
Postby JohanVanDyck » Mon Oct 05, 2015 7:46 pm
Hi
Via private message, I was asked where to find the user table. (I can't reply on that message in private) but:
- I use phpmyadmin to have a view on my database. But you can also use the hard way...
- I open the domotiga db, in the "users" table the columns "username" and "password" exist.
via mysql use this querry: (db name = domotiga in my case; name is choosen @ installation)
>mysql -u root -p
mysql> use domotiga
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> SELECT * FROM `users` WHERE `fullname`="admin";
| id | username | password | fullname | admin | comments | lastlogin | emailaddress | cookie |
| 1 | admin | MD5AQxbz2WH4CZ72Z4F5SvrJcKgkFJ8S1 | Admin | 1 | | 2008-11-06 14:12:13 | admin@mydomain.com | |
1 row in set (0.00 sec)
mysql> quit
Regards
Johan.
JohanVanDyck
Postby JohanVanDyck » Mon Oct 05, 2015 8:31 pm
Hi
You can find the table users in your database (domotiga). I use phpmyadmin, but via mysql
$mysql -uroot -p
mysql> use domotiga
Database changed
| 1 | admin | MD5AQxbz2WH4CZ72Z4F4SvrJcKgkFJ9S1 | Admin | 1 | | 2008-11-06 14:12:13 | admin@mydomain.com | |
mysql> quit;
JohanVanDyck
Postby Edwin » Wed Oct 07, 2015 7:26 am
Thank u very much
For your help
Greetings
Edwin
Edwin
Return to DomotiGa Forum
