Time not in sync?
Posted: Mon Oct 19, 2015 10:03 am
by Edwin
I cant get the time in sync at my raspberry i entered the lines server 0.nl.pool.ntp.org etc.
but the time doesnt sync with the real time.
Ntpq -p gives this output:
I get this output:
oll reach delay offset jitter ==============================================================================
*alpha.jpunix.ne 82.95.215.61 2 u 47 64 77 11.606 -6.675 0.598
ntp01.solcon.nl 193.67.79.202 2 u 36 64 7 12.152 -5.576 0.266
+146.185.130.223 129.70.132.33 3 u 33 64 77 11.965 -0.864 0.467
+ns1.tomhek.net 31.3.104.60 3 u 40 64 77 11.505 -4.812 0.807
Any ideas?
Re: Time not in sync?
Posted: Mon Oct 19, 2015 10:42 am
by raymonvdm
If you run NTPD you need at least 3 working time servers.
root@ntp01:/# ntpq -p
remote refid st t when poll reach delay offset jitter
-ntp0.nl.uu.net .PPS. 1 u 908 1024 377 2.306 0.075 0.375
-ntp1.nl.uu.net .PPS. 1 u 914 1024 377 2.673 0.298 0.314
*ntp1.oma.be .MRS. 1 u 629 1024 377 8.196 -0.501 0.480
+ntp2.oma.be .PPS. 1 u 334 1024 377 8.978 -0.452 0.119
-ntp0.rrze.uni-e .GPS. 1 u 956 1024 377 11.518 0.124 0.142
+ntp-sop.inria.f .GPS. 1 u 454 1024 377 30.644 -0.218 0.248
-ntp.xs4all.nl 193.79.237.14 2 u 365 1024 377 1.635 -0.070 0.185
-213.75.85.246 .PPS. 1 u 699 1024 377 4.974 0.433 0.210
root@ntp01:/#
The above server is actually member of the
ntppool
cat /etc/ntp.conf
server ntp0.nl.net 193.67.79.202
server ntp1.nl.net 193.79.237.14
server ntp1.oma.be 193.190.230.65
server ntp2.oma.be 193.190.230.66
server ntp0.fau.de 131.188.3.220
server canon.inria.fr 192.93.2.20
server ntp.xs4all.nl 194.109.22.18
server ntp.wxs.nl 213.75.60.246
Or just run ntpdate from
cron
Posted: Mon Oct 19, 2015 11:48 am
by Edwin
i get this wit ntpdate:
19 Oct 09:45:05 ntpdate[5373]: no servers can be used, exiting
what i`m doing wrong?
ntpq -p gives:
+ntp0.nl.uu.net .PPS. 1 u 29 64 77 10.880 -0.220 0.590
*ntp1.nl.uu.net .PPS. 1 u 24 64 77 10.686 -0.056 0.627
+ntp1.oma.be .MRS. 1 u 30 64 77 15.710 0.167 0.971
+ntp2.oma.be .PPS. 1 u 27 64 77 15.718 0.135 0.613
+ntp0.rrze.uni-e .GPS. 1 u 24 64 77 22.649 0.138 0.398
-ntp-sop.inria.f .GPS. 1 u 23 64 77 35.203 -3.079 0.607
+ntp2-1.xs4all.n 193.67.79.202 2 u 21 64 77 9.816 -0.311 0.700
-213.75.60.246 .PPS. 1 u 21 64 77 13.281 1.240 0.505
can you show me youre config file Raymon so i can see if i did something wrong?
thank for your help
Posted: Mon Oct 19, 2015 12:45 pm
by raymonvdm
The rest of the config is default config out of the ntp package
You might first need to stop ntp(d)
/etc/init.d/ntpd stop
or
/etc/init.d/ntp stop (depend on the actual package name i think)
I can then use ntpdate without issues
ntpdate ntp01.solcon.nl
19 Oct 12:39:53 ntpdate[11345]: adjust time server 2001:9e0:4:32::250 offset 0.067353 sec
or to rule out dns issues
If this is working you can try to purge and reinstall the package to get ntpd working
apt-get purge ntp
apt-get install ntp
Posted: Mon Oct 19, 2015 7:04 pm
by Edwin
i dit purge and install ntp
time was still wrong after that i did : cp /usr/share/zoneinfo/Europe/Amsterdam /etc/localtime
started the time server and now it works
thanks
