Page 1 of 3
Nefit easy support?
Posted: Wed Jan 06, 2016 12:54 pm
by Edwin
Re: Nefit easy support?
Posted: Wed Jan 06, 2016 2:28 pm
by RDNZL
Not native.
You can alter the Python script from one of the first posts to gather the Nefit values and convert the output to json calls to set DomotiGa's device values.
Setting the temp is also possible this way using a 'Shell' type devices, or a script event action.
https://domotiga.nl/projects/domotiga/w ... RPC#Python
https://domotiga.nl/projects/domotiga/w ... C#valueset
If you need help let us know.
Posted: Wed Jan 06, 2016 3:47 pm
by Edwin
That is the problem i dont know how to that.
Have no scripting or program skils
Posted: Wed Jan 06, 2016 4:17 pm
by RDNZL
And I haven't got a Nefit CV
Can you install the easy nefit command like described, make it output the data you want in the cli?
With that output I can code something.
Posted: Wed Jan 06, 2016 7:41 pm
by Edwin
i will thank for your support
Posted: Thu Jan 07, 2016 1:47 am
by pepijn
If you read the full topic, a Node RED node is also available, you could use Node RED to publish data. This is also the way they do it for Domoticz
Posted: Sat Jan 09, 2016 4:55 pm
by RDNZL
Nice suggestion Pepijn!
I played with it, and create the following wiki page describing how to implement this for DomotiGa.
It can be optimized taking out the whole MQTT part, but maybe I will do this later.
Since I don't have a Nefit CV, I tested the flow by having the scripts return hardcoded JSON test data.
Edwin, maybe the installation notes of the nefit-easy-cli package are not correct, please test and let me know.
https://domotiga.nl/projects/domotiga/wiki/Node-RED
Posted: Sat Jan 09, 2016 6:44 pm
by Edwin
Verry nice,
thank you
I will try it as soon i have the time
i let u know the results.
regards, edwin
Posted: Sun Jan 10, 2016 12:18 am
by Edwin
RDNZL wrote:Nice suggestion Pepijn!
node -v gives me: " segmentation fault" ?
see this:
root@raspberrypi:~# apt-get install -y nodejs
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
gambas3-examples gambas3-gb-jit libllvm3.1
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
nodejs
0 upgraded, 1 newly installed, 0 to remove and 132 not upgraded.
Need to get 0 B/762 kB of archives.
After this operation, 2,395 kB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ... 86245 files and directories currently installed.)
Unpacking nodejs (from .../nodejs_0.6.19~dfsg1-6_armhf.deb) ...
Processing triggers for man-db ...
Setting up nodejs (0.6.19~dfsg1-6) ...
update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto m ode
root@raspberrypi:~# node -v
Segmentation fault
root@raspberrypi:~#
Posted: Sun Jan 10, 2016 10:28 am
by pepijn
That's quick
In see you use the the nefit-easy-client commandline tools. In then meanwhile a 'native' node-red node has been developed (npm -g i node-red-contrib-nefit-easy)
You could also check the thread on the Domoticz forum for more information.
Posted: Sun Jan 10, 2016 12:51 pm
by RDNZL
Which Debian version do you run on your Pi?
$ cat /etc/debian_version
jessie/sid
$ uname -a
Linux rdznl 3.19.0-39-generic #44~14.04.1-Ubuntu SMP Wed Dec 2 10:00:35 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Maybe your distro is not suited to run 5.x nodejs, or something else is wrong, can you try nodejs 4.x version with these steps:
Remove 5.x nodejs:
Remove 5.x source repo:
$ sudo rm -f /etc/apt/sources.list.d/nodesource.list*
$ sudo apt-get update
Install 4.x
$ mkdir -p ~/install/nodejs
$ cd ~/install/nodejs
$ curl -sL https://deb.nodesource.com/setup_4.x | bash -
$ sudo apt-get install -y nodejs
Let me know how this works, so I can update the wiki page for your distro.
Posted: Sun Jan 10, 2016 1:47 pm
by Edwin
Hi, Ron
it doesnt work
i uninstalled version 5.x and installed 4.x
still the same problem, is it the version on my raspberry?
this is it: Linux raspberrypi 4.1.7+ #817 PREEMPT Sat Sep 19 15:25:36 BST 2015 armv6l GNU/Linux
sorry im a noob at this so i cant solve it my self
thanks for youre help
Posted: Sun Jan 10, 2016 2:57 pm
by RDNZL
Another attempt:
Remove broken stuff:
$ sudo apt-get purge nodejs
Install Pi armv6l version:
$ wget https://nodejs.org/dist/v5.3.0/node-v5.3.0-linux-armv6l.tar.gz
$ tar -xvf node-v5.3.0-linux-armv6l.tar.gz
$ cd node-v5.3.0-linux-armv6l
$ sudo cp -R * /usr/local/
$ node -v
Posted: Sun Jan 10, 2016 7:42 pm
by Edwin
Hi, Ron
this part is ok:
$ node -v
v5.3.0
$ npm -v
3.3.12
but node red doesnt start with: $ node-red gives error: node-red: command not found
this is in the install directory: root@raspberrypi:~/install# dir
libk8055 nodejs node-red
and in node-red directory:
bin Gruntfile.js locales package.json red.js
CONTRIBUTING.md lib node_modules README.md settings.js
editor LICENSE nodes red test
what can be wrong?
thanksards Edwin
reg
Posted: Sun Jan 10, 2016 8:14 pm
by pepijn
