Page 2 of 3
Re: Nefit easy support?
Posted: Sun Jan 10, 2016 11:35 pm
by pepijn
pepijn wrote:
RDNZL wrote:Nice suggestion Pepijn!
I played with it, and create the following wiki page describing how to implement this for DomotiGa.
It can be optimized taking out the whole MQTT part, but maybe I will do this later.
Since I don't have a Nefit CV, I tested the flow by having the scripts return hardcoded JSON test data.
Edwin, maybe the installation notes of the nefit-easy-cli package are not correct, please test and let me know.
https://domotiga.nl/projects/domotiga/wiki/Node-RED
That's quick :)
In see you use the the nefit-easy-client commandline tools. In then meanwhile a 'native' node-red node has been developed (npm -g i node-red-contrib-nefit-easy)
You could also check the thread on the Domoticz forum for more information.
To complete this info:
flows.nodered.org/node/node-red-contrib ... nefit-easy
Posted: Mon Jan 11, 2016 7:26 am
by Edwin
pepijn wrote:Could you try
node red.js -v
Gives : could not find module
Looks like it isnt installed?
Strange
I hear from you
Thank for youre support
Regards edwin
Posted: Wed Jan 13, 2016 9:14 pm
by pepijn
Today i released a new version of the node-red node. Please check the Domoticz forum for an example flow. It should work on any MQTT supported system.
Posted: Wed Jan 13, 2016 9:16 pm
by pepijn
node red.js -v
Strange
I hear from you
Regards edwin
I'm not running on a Pi myself so it's hard to replicate your problem. It seems Node(red) is not installed correctly
Posted: Wed Jan 13, 2016 9:22 pm
by Edwin
node-red is still not working
reinstalled it but i get warnings:
npm WARN deprecated i18next-client@1.10.3: you can use npm install i18next from version 2.0.0
npm WARN deprecated lodash@0.9.2: lodash@<2.0.0 is no longer maintained. Upgrade to lodash@^3.0.0
npm WARN deprecated lodash@1.0.2: lodash@<2.0.0 is no longer maintained. Upgrade to lodash@^3.0.0
npm WARN install Couldn't install optional dependency: Unsupported
npm WARN deprecated npmconf@2.1.2: this package has been reintegrated into npm a nd is now out of date with respect to npm
generateActionsToTake → d ▄ ╢███████████████████████████████████████████████████████░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░╟
node red.js -v
$ node -v
v5.3.0
$ npm -v
3.3.12
but node red doesnt start with: $ node-red gives error: node-red: command not found
this is in the install directory: root@raspberrypi:~/install# dir
libk8055 nodejs node-red
and in node-red directory:
bin Gruntfile.js locales package.json red.js
CONTRIBUTING.md lib node_modules README.md settings.js
editor LICENSE nodes red test
Posted: Thu Jan 14, 2016 10:14 am
by pepijn
Edwin wrote:node-red is still not working
node red.js -v
$ node -v
v5.3.0
$ npm -v
3.3.12
How did you install node-red?
npm -g install node-red
Posted: Thu Jan 14, 2016 11:04 am
by Edwin
I installed it with the wiki provided:
We have successfully configured Node.js, we can now download Node-RED.
The latest Node-RED version can be fetched from it's GIT repository so that we can work on it's most recent version updated with any new commits.
To download from GIT, you must make sure that you have GIT package installed.
If it is not there, run the following command to get the GIT installed on your system.
$ sudo apt-get install git-core
After successfully installing GIT, navigate to your home directory to continue with Node-RED installation.
I’ll now list out the steps that you will be executing to first clone the Node-RED repository and then install it using the “npm” command which is the Node Package Manager that we had earlier setup during Node.js installation.
$ cd ~
$ mkdir -f install
$ cd install
$ git clone https://github.com/node-red/node-red.git
$ cd node-red
$ sudo npm install
Is this the wrong way?
Posted: Thu Jan 14, 2016 11:54 am
by pepijn
I would try npm -g install node-red
Posted: Thu Jan 14, 2016 12:21 pm
by Edwin
I will try it.
I let u know the results
Thanks
Posted: Sat Jan 16, 2016 12:04 am
by pepijn
Edwin wrote:I will try it.
Thanks
Did you get it to work?
Posted: Sat Jan 16, 2016 1:07 pm
by Edwin
No, tried many times
But still it doesnt work :-(
npm ERR! Linux 4.1.7+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "npm" "-g"
npm ERR! node v5.3.0
npm ERR! npm v3.3.12
npm ERR! path /usr/local/lib/node_modules/.staging/npm-50a4982228b2af3f85663ed45ae26391/package.json
npm ERR! code ENOENT
npm ERR! errno -2
npm ERR! syscall open
npm ERR! enoent ENOENT: no such file or directory, open '/usr/local/lib/node_modules/.staging/npm-50a4982228b2af3f85663ed45ae26391/package.json'
npm ERR! enoent This is most likely not a problem with npm itself
npm ERR! enoent and is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! Please include the following file with any support request:
npm ERR! /root/npm-debug.log
root@raspberrypi:~# npm install -g --unsafe-perm node-red
npm WARN install:mime@1.3.4 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node-pre-gyp- github/node_modules/mime/cli.js'
npm WARN install:har-validator@2.0.3 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node -pre-gyp-github/node_modules/request/node_modules/har-validator/bin/har-validator'
npm WARN install:sshpk@1.7.1 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node-pre-gyp -github/node_modules/request/node_modules/http-signature/node_modules/sshpk/bin/sshpk-conv'
npm WARN install:node-uuid@1.4.7 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node-pre -gyp-github/node_modules/request/node_modules/node-uuid/bin/uuid'
npm WARN install:mkdirp@0.5.1 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node-pre-gy p/node_modules/mkdirp/bin/cmd.js'
npm WARN install:nopt@3.0.6 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node-pre-gyp/ node_modules/nopt/bin/nopt.js'
npm WARN install:strip-json-comments@1.0.4 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_module s/node-pre-gyp/node_modules/rc/node_modules/strip-json-comments/cli.js'
npm WARN install:har-validator@2.0.3 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node -pre-gyp/node_modules/request/node_modules/har-validator/bin/har-validator'
npm WARN install:sshpk@1.7.1 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node-pre-gyp /node_modules/request/node_modules/http-signature/node_modules/sshpk/bin/sshpk-conv'
npm WARN install:node-uuid@1.4.7 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node-pre -gyp/node_modules/request/node_modules/node-uuid/bin/uuid'
npm WARN install:rimraf@2.4.4 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node-pre-gy p/node_modules/rimraf/bin.js'
npm WARN install:semver@5.1.0 ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/serialport/node_modules/node-pre-gy p/node_modules/semver/bin/semver'
/usr/local/bin/node-red -> /usr/local/lib/node_modules/node-red/red.js
/usr/local/bin/node-red-pi -> /usr/local/lib/node_modules/node-red/bin/node-red-pi
/usr/local/lib
└── node-red@0.12.5
root@raspberrypi:~# node-red
Node-RED has not been built. See README.md for details
Nefit easy support?
Posted: Sat Jan 16, 2016 5:27 pm
by pepijn
Could you uninstall node and install it from the node source repositories
curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
sudo apt-get install -y nodejs
Posted: Sun Jan 17, 2016 11:02 am
by Edwin
i will
i let you know the results.
thanks
Posted: Sun Jan 17, 2016 11:09 am
by Edwin
get this error:
root@raspberrypi:~# sudo apt-get install -y nodejs
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nodejs : Depends: libc6 (>= 2.16) but 2.13-38+rpi2+deb7u8 is to be installed
Depends: libstdc++6 (>= 5.2) but 4.8.2-21~rpi3rpi1 is to be installed
E: Unable to correct problems, you have held broken packages.
root@raspberrypi:~#
Posted: Sun Jan 17, 2016 1:38 pm
by pepijn
Assuming you have a model A
wget https://nodejs.org/dist/v4.1.1/node-v4.1.1-linux-armv6l.tar.gz
tar -xvf node-v4.1.1-linux-armv6l.tar.gz
cd node-v4.1.1-linux-armv6l
If you have a pi2 replace armv6l by armv7l
