ARM architecture support
Moderator: RDNZL
Merdeka
Post by Merdeka »
I'm recompiling gambas on a NSLU2 running debian. Didn't compile support in for firebird the first time.
Got segmentation faults when trying to run DomotiGaServer.
I'l get back when it's done. But it takes ages to compile anything on a slug.
It's also running http://usb-server.com/ , EIBd and a mysql server so i'll hope it will run DomotigaServer a bit responsive.
RDNZL
Re: Handling long running items without pausing the main loop
Post by RDNZL »
ARM support in Gambas is very new, so I suspect that even with firebird installed there gonna be problems.
Only one person has tested ARM support until now, and that was running in a virtual ARM environment.
Can you e-mail me the steps you took to get gambas onto your nslug, which image etc you are running, I have one laying around too (somewhere) :wink: , so if I can get it running fast I can send bug-reports to the Gambas developer to get them fixed.
Regards, Ron.
Merdeka
Re: ARM architecture support
Post by Merdeka »
Thanks to Benoît (Gambas developer) DomotigaServer has been running on my NSLU2 for a few days now.
It works really well. With the EIB, Digitemp, DSC, Gmail and Pachube support enabled I see about 15MB memory usage.
Had to modify the CDSC.class because I ran into a bug and am working on the UDP server now.
So all in all... very happy with DomotiGa on a NSLU2.
Carlo
Post by Carlo »
Hi Merdeka, is the 15MB memory usage for the complete application including your Linux distro, or only for the Domotiga server with drivers? If it's only for the Domotiga server, what is the complete memory usage for your whole system, including Linux?
Merdeka
Post by Merdeka »
Carlo,
That's for DomotigaServer only. However, i left it running for 2 days and memory increased to 18.5mb then it dropped to 10.9mb and stayed there for 1 day. I restarted DomotigaServer a couple of minutes ago and it's 13.2 now. Don't know why it's lower or why it dropped.
See the info that top gives for more info on mem usage.
I run a compiled version of DomotigaServer so gbr2 is the processname.
I would like to replace the sshd for a ssh server that uses less memory. Only thing is.. if I screw it up the NSLU2 is unaccessible.
Tasks:  43 total,   1 running,  42 sleeping,   0 stopped,   0 zombie
Cpu(s):  0.9%us,  0.9%sy,  0.0%ni, 97.9%id,  0.2%wa,  0.0%hi,  0.0%si,  0.0%st
Mem:     29508k total,    28332k used,     1176k free,     1536k buffers
Swap:   248968k total,     5396k used,   243572k free,    10800k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
28198 timo      20   0  2476 1008  820 R  5.5  3.4   0:00.11 top
    1 root      20   0  1968  304  276 S  0.0  1.0   0:06.31 init
    2 root      15  -5     0    0    0 S  0.0  0.0   0:00.01 kthreadd
    3 root      15  -5     0    0    0 S  0.0  0.0   3:24.57 ksoftirqd/0
    4 root      RT  -5     0    0    0 S  0.0  0.0   0:00.00 watchdog/0
    5 root      15  -5     0    0    0 S  0.0  0.0   0:01.72 events/0
    6 root      15  -5     0    0    0 S  0.0  0.0   0:00.02 khelper
   45 root      15  -5     0    0    0 S  0.0  0.0   0:00.19 kblockd/0
   50 root      15  -5     0    0    0 S  0.0  0.0   0:00.00 kseriod
   76 root      20   0     0    0    0 S  0.0  0.0   0:00.01 pdflush
   77 root      20   0     0    0    0 S  0.0  0.0   0:00.86 pdflush
   78 root      15  -5     0    0    0 S  0.0  0.0   0:03.71 kswapd0
   79 root      15  -5     0    0    0 S  0.0  0.0   0:00.00 aio/0
  193 root      15  -5     0    0    0 S  0.0  0.0   0:00.00 mtdblockd
  222 root      15  -5     0    0    0 S  0.0  0.0   0:00.00 kpsmoused
  289 root      15  -5     0    0    0 S  0.0  0.0   0:01.09 khubd
  330 root      15  -5     0    0    0 S  0.0  0.0   0:00.00 scsi_eh_0
  331 root      15  -5     0    0    0 S  0.0  0.0   0:51.02 usb-storage
  703 root      15  -5     0    0    0 S  0.0  0.0   0:08.33 kjournald
  790 root      16  -4  2240  264  260 S  0.0  0.9   0:01.67 udevd
 1360 daemon    20   0  1732  212  208 S  0.0  0.7   0:00.01 portmap
 1387 statd     20   0  1820  256  252 S  0.0  0.9   0:00.06 rpc.statd
 1480 root      20   0 28556 1216  876 S  0.0  4.1   0:15.82 rsyslogd
 1493 messageb  20   0  2656  200  196 S  0.0  0.7   0:00.01 dbus-daemon
 1508 root      20   0  5552  524  420 S  0.0  1.8   0:08.01 sshd
 1775 Debian-e  20   0  6896  348  296 S  0.0  1.2   0:00.24 exim4
 1812 root      20   0  3640  180  176 S  0.0  0.6   0:00.01 famd
 1820 daemon    20   0  1992  232  220 S  0.0  0.8   0:00.04 atd
 1844 root      20   0  2136  328  276 S  0.0  1.1   0:02.52 cron
 1886 root      20   0  1560  236  232 S  0.0  0.8   0:00.03 getty
 2685 timo      20   0  3136 1028  584 S  0.0  3.5   0:20.65 screen
 2686 timo      20   0  4728 1080  792 S  0.0  3.7   0:02.71 bash
21186 ntp       20   0  4736  932  800 S  0.0  3.2   6:28.25 ntpd
27871 root      20   0  8480 2536 2076 S  0.0  8.6   0:00.66 sshd
27879 timo      20   0  8480 1708 1248 S  0.0  5.8   0:00.11 sshd
27880 timo      20   0  4720 3124 1268 S  0.0 10.6   0:02.52 bash
27907 timo      20   0  2868  952  764 S  0.0  3.2   0:00.07 screen
27910 timo      20   0 20732 3888 2964 S  0.0 13.2   0:03.49 gbr2
28040 root      20   0  8480 2532 2072 S  0.0  8.6   0:00.62 sshd
28044 timo      20   0  8628 1724 1252 S  0.0  5.8   0:00.35 sshd
28045 timo      20   0  4720 3132 1276 S  0.0 10.6   0:02.48 bash
28196 root      20   0  7264 2396 1936 S  0.0  8.1   0:00.55 sshd
28197 sshd      20   0  6896 1508 1084 S  0.0  5.1   0:00.14 sshd
SRG
Post by SRG »
I really would like to know what you did to have a running DomotiGa Server on an ARM computer ?
I've just installed a fresh Debian Squeeze (ARM) on a plug computer (ionics stratus 1.2Ghz Marvell).
Installed gambas from .deb packages (apt-get install gambas2 + all modules).
Recompiled .gambas from SVN (maybe not necessary, don't know).
But now when i start the server, i have a "segmentation fault" error, i really don't know what to do.
2011/02/23 23:22:43 ---- Program Restart ----
2011/02/23 23:22:43 Starting DomotiGaServer V0.1.194 last updated on 2011-02-23 at 23:17:20
2011/02/23 23:22:43 Running on stratus (pid 29430) as user root (id 0) with language en_US.UTF-8
2011/02/23 23:22:43 Program base directory is '/home/applications/domotiga'.
2011/02/23 23:22:43 Database settings are loaded from 'server-domotiga.conf'.
2011/02/23 23:22:43 Active logfiles are 'server-main-2011-02.log', 'server-speak-2011-02.log' and 'server-debug-2011-02.log'.
2011/02/23 23:22:43 Running on Gambas version 2.21.0
2011/02/23 23:22:43 Server uptime is 23:22:43 up 4 days, 23:25, 1 user, load average: 0.09, 0.12, 0.0
2011/02/23 23:22:43 Checking directory structure ...
2011/02/23 23:22:43 Connecting to database ...
2011/02/23 23:22:43 Loading modules ...
2011/02/23 23:22:43 Starting setup ...
zsh: segmentation fault DomotiGaServer.gambas
I tried the "debug" way with gdb but with no success.
GNU gdb (GDB) 7.0.1-debian
Copyright (C) 2009 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "arm-linux-gnueabi".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
(gdb) set args -p /home/applications/domotiga/SVN/DomotiGaServer
(gdb) exec-file gbr2
(gdb) run
Starting program: /usr/bin/gbr2 -p /home/applications/domotiga/SVN/DomotiGaServer
[Thread debugging using libthread_db enabled]
2011/02/23 23:28:51 ---- Program Restart ----
2011/02/23 23:28:51 Starting DomotiGaServer V0.1.194 last updated on 2011-02-23 at 23:28:23
2011/02/23 23:28:51 Running on stratus (pid 29479) as user root (id 0) with language en_US.UTF-8
2011/02/23 23:28:51 Program base directory is '/home/applications/domotiga/SVN/'.
2011/02/23 23:28:51 Database settings are loaded from 'server-domotiga.conf'.
2011/02/23 23:28:51 Active logfiles are 'server-main-2011-02.log', 'server-speak-2011-02.log' and 'server-debug-2011-02.log'.
2011/02/23 23:28:51 Running on Gambas version 2.21.0
2011/02/23 23:28:51 Server uptime is 23:28:51 up 4 days, 23:31, 1 user, load average: 0.00, 0.03, 0.0
2011/02/23 23:28:51 Checking directory structure ...
2011/02/23 23:28:51 Connecting to database ...
2011/02/23 23:28:51 Loading modules ...
2011/02/23 23:28:51 Starting setup ...
Program received signal SIGSEGV, Segmentation fault.
0x00020354 in ?? ()
(gdb)
Of course i have a mysql running with domotiga schema, user, datas, and so on (in fact everything replicated from another x86 server).
SRG
Post by SRG »
Ok after removing the Gambas .deb packages (every packages) and installing the latest stable version from sources, it works, this time.
(i was in .21 from Debian Squeeze and went to .22 from sources)
RDNZL
Post by RDNZL »
A lot of ARM bugs where fixed in latest Gambas version, so you did the right thing by compiling from source.
Regards, Ron.
tickett
Post by tickett »
I too managed get it going by compiling source 2.24 on my raspberry pi running debian http://tickett.wordpress.com/2012/06/04 ... ood-to-go/
Return to “DomotiGa Forum”
