Philips TV jointSPACE support?
Moderator: RDNZL
Postby RDNZL » Mon Aug 09, 2010 7:40 pm
The latest Firmware (from 15/07/2010) for my Philips TV supports an open protocol called jointSPACE.
This version is a USB only upgrade so when you let your TV search for updates via de LAN/Internet it won't find it, you have to download it yourself to a USB stick and upgrade your TV.
With this you can build modules to be installed on the home screen, you can use the TV to display content from remote devices (via directFB)
and you can control your TV via the LAN/WIFI.
Are there any DomotiGa users who have a Philips xxxPFL9xxx series (or certain 8xxx series) TV like me, with some spare time who could help building DomotiGa support for it?
Would be nice to be able to control certain parts of the TV and to be able to have OSD from DomotiGa to your TV's without the need for extra hw.
Displaying your home automation status graphically etc...
There is a simulator for Linux (not tested yet), and SDK's for Windows, Linux, Mac, iPhone, even an Nintendo DS can display text on it... :P
The source is also available, so if anyone can build an Android SDK that would be nice too.. :wink:
Look here for more info...
http://jointspace.sourceforge.net/ Main site
http://jointspace.sourceforge.net/download.html SDK and sample apps
jointspace.sourceforge.net/projectdata/ ... _Linux.pdf One of the interesting presentations... Great work Philips...
It all looks very new, so more info and apps will appear soon I guess...
Regards, Ron.
RDNZL
Re: Philips TV jointSPACE support?
Postby sanderr » Mon Mar 07, 2011 10:05 pm
I have just released the tool JSTx as a BETA. JSTx is a basic command line utility that will allow jointSPACE commands to be sent to supporting displays. It is available for Linux (32-bit only for now) on https://sourceforge.net/projects/jstx.
The tool is written with Domotica like applications/advanced users in mind (hence: command line only), and is kept simple for now. Future plans include a client-/server-model and more primitives (such as image support).
Sander
sanderr
Postby RDNZL » Wed Mar 09, 2011 9:53 am
./JSTx -W 1280 -H 720 -w 1280 -h 25 -x 0 -y 0 -t "Testing DomotiGa OSD" -D 1 --dfb:remote=192.168.178.6,quiet
The above test works!
Now callerid, and other event information can be displayed on my tv without any extra hardware or running devices, great!
I will test interaction with the TV remote and other functions soon.
Regards, Ron.
RDNZL
Postby Bwired » Wed Mar 09, 2011 3:35 pm
This is great!, I was planning to buy the new philips 21:9, my current philips has no lan :(
Postby RDNZL » Wed Mar 09, 2011 4:00 pm
Also the android app remote is working great, I can turn the sound down with my nexus one if my children don't want to listen when I ask to lower the volume. :D Or switch channels...
I haven't tested the iPad/Phone app yet...
Philips is ruling when it comes to open-source sdk's and their TV's as far as i'm concerned...
DomotiGa knows if the tv is on, so all kinds of possible scenarios can be build, OSD: There is someone in front of door, open it? 1=yes, 0=no
It's all possible if I look at JSTx...
Regards, Ron.
RDNZL
Postby Bwired » Fri Mar 11, 2011 5:12 pm
Youtube video
Postby RDNZL » Sun Mar 13, 2011 5:35 pm
Something remotely related; I have also bought a HTS9140 Blueray Soundbar for cheap (via friends with loads of "ING spaarpunten")
It has the same menu interface as my TV, and it also runs Linux, didn't try to see if this supports JointSpace too yet.
You have to enable it via the remote control once.
But it sure plays all of my 1080p MKV files directly from my Synology NAS perfectly, with DTS5.1, AC3, subtitles, the whole shebang.
So I don't need a seperate mediaplayer too... Philips is heading in the right direction.
I didn't succeed yet in displaying cover.jpg's while browsing media, but that's not a big issue for me.
Maybe a future firmware update fixes this.
Regards, Ron.
RDNZL
Postby sanderr » Sun Mar 13, 2011 8:19 pm
A new version of JSTx is available at https://sourceforge.net/projects/jstx (V0.11). This version will allow a more 'scripted' mode of operation as it can read from a text file (continuously...) and forward keys to the underlying application ('proxy mode') so you could keep watching TV while reading the latest News in the window below. Download it while it's fresh :)
sanderr
Postby Harry » Sun May 08, 2011 11:45 am
i running the app on the iphone now, works great. it responses even faster then the remote control :P
i am using it whit the 21:9 cinema
are there intagrations for homeseer?
would be great i could control the tv trough the homeseer server.
Postby ccc » Sat Dec 03, 2011 3:21 pm
sanderr wrote:A new version of JSTx is available at https://sourceforge.net/projects/jstx (V0.11). This version will allow a more 'scripted' mode of operation as it can read from a text file (continuously...) and forward keys to the underlying application ('proxy mode') so you could keep watching TV while reading the latest News in the window below. Download it while it's fresh :)
Hi Sanderr & others
do you know if JSTx works on an optware kind of environment, like a Synology NAS?
Did anyone try to compile it there?
tx
ccc
Postby sanderr » Fri Feb 17, 2012 1:26 pm
did not try to compile it on a NAS, but did make a build for the Nokia N900 (ARM-based) available on SF. So, a generic Linux embedded environment like an N900 - which *some* NAS typically are - could work. I do recommend static compilation, and I warn that I saw some issues regarding PNG usage on the N900 - your mileage may vary.
Good luck,
Sander
sanderr
Postby Mglath » Sat Jun 23, 2012 8:44 am
RDNZL wrote:Something remotely related; I have also bought a HTS9140 Blueray Soundbar for cheap (via friends with loads of "ING spaarpunten")
Hi Ron,
Any luck on your question here? I'm on kind of the same quest. Also have a hts9140 soundbar (unfortunately full price form me) and I want to be able to controle it via my iPad.
I bought a synology nas that can stream the music, but with the current setup I need the tv to see what I'm selecting/playing. It should be possible to push the music form the nas to the soundbar in stead of pull it.
Hope some one can help here. The firmware of the hts is open source, but Im not techy enough for that.
Mglath
Postby RDNZL » Sun Jun 24, 2012 11:13 am
I requested the open-source code from Philips the day after I got the soundbar, I received a 500MB file called "OSS HTS9140-12.zip" ;-)
Unpacked it's 1.36GB, a quick look reveals mostly Linux kernel module code... will take a look at the rest soon... but it's not very useful I guess..
Regards, Ron.
RDNZL
Postby DJF3 » Wed Jul 04, 2012 12:04 pm
I have created scripts that allow you to execute Jointspace commands through Homeseer.
PROBLEM: "hs.GetURL" uses an Internet Explorer engine which does not support JSON as it should (surprise, surprise)
So it actually doesn't work, unless you know a way to get this working. I probably could use WGET to call the URL's (haven't tested that) but that's not as nice.
You can use the ASP to directly call URLS that execute commands.
More info & downloads: domoticaworld.com/scripts/tv-control-ph ... l-philips/
Cheers
DJ
DJF3
Postby Bwired » Wed Jul 04, 2012 10:11 pm
thanks DJ, really good jointspace information.
Next
Return to DomotiGa Forum
