dom/bright switch Heyu X10commander with CM11
Moderator: RDNZL
Re: dom/bright switch Heyu X10commander with CM11
Postby Bennieo » Sun Mar 10, 2013 12:07 pm
When I use the slider, The Dimmer isn't working.
log file:
2013/03/10 12:01:01 [RFXComTRX] Unknown Lighting1 command 'DIM 29' given!
2013/03/10 12:01:03 [RFXComTRX] Unknown Lighting1 command 'DIM 29' given!
2013/03/10 12:01:12 [RFXComTRX] Unknown Lighting1 command 'DIM 60' given!
2013/03/10 12:01:13 [RFXComTRX] Unknown Lighting1 command 'DIM 60' given!
2013/03/10 12:01:14 [RFXComTRX] Unknown Lighting1 command 'DIM 79' given!
2013/03/10 12:01:16 [RFXComTRX] Unknown Lighting1 command 'DIM 79' given!
(ie. you can not gradually dim up from the off state).
Correct.. When I try to dim in the Off state, the log reports:
12:02:57 [RFXComTRX] Unknown Lighting1 command 'DIM 0' given!
Bennieo
Postby RDNZL » Sun Mar 10, 2013 4:58 pm
Dim/Bright isn't implemented in DomotiGa's RFXcomTRX code right now.
Simply because I couldn't imagine someone would use it, you can't do absolute dimming, just up/down, ie dim/bright.
You now seem to have extended x0 enabled so you get a slider instead of +/- buttons.
But Dim 27 will never work with X10.
Regards, Ron.
RDNZL
Re: dim/bright switch Heyu X10commander with CM11
Postby Bennieo » Mon Mar 11, 2013 7:27 am
Thanks Ron,
The purpose is dimming the whole livingroom when I want to see a movie or when I turn on the fireplace :wink: .. With one function dimming all the lights in the livingroom.. :D
I tried the +/- buttons as well but no luck. After the +/- buttons I tried the slider with extended x10 enabled.
Bennieo
Postby Bennieo » Wed Mar 13, 2013 1:20 pm
I want to use dimming also for my window-shutters ( SW10 shutterswitch).. Now I can only open or close the shutters.. With a dimfunction I'm able to open or close the shutters halfway or a percent of it.
Bennieo
Postby RDNZL » Wed Mar 13, 2013 4:44 pm
I have added the dim and bright commands to the last code.
Maybe you can try it.
Regards, Ron.
RDNZL
Postby Bennieo » Fri Mar 15, 2013 9:03 pm
How can I use the last code to test it?.. :shock:
Bennieo
Postby RDNZL » Fri Mar 15, 2013 10:19 pm
Update/copy the code and binaries from svn (svn up in domotiga dir) and set the device to normal dimming (ie do not enabled extended X10)
then you should get + and - buttons on control panel.
clicking them should send dim and bright commands.
Regards, Ron.
RDNZL
Postby Bennieo » Sun Mar 17, 2013 12:46 pm
It works..!!! in about six steps I'm able to dim the light.. :D
Bennieo
Previous
Return to DomotiGa Forum
