after reading the manual i managed installing my TEMP08 device recently bought on this forum in Ubuntu. Now enabled it in domotiga.
When i do an ini in the serial monitor i get:
Readin Sensor...
01 2B00000075248226 DS248 OK P V
Update interva = 01 minutes
Temp dislay = C
Serial display = On
Wind dirn rever = Off
Qty ofDS1820=0
Qty ofDS1822=00
Qty of DS18B2=0
Qty ofDS2438=01
SAT 3:06:06
so i made a device with type 1-wire, device Dallas DS2438 and interface Midon TEMP08. I Enabled it but I don see any readings. Did I do something wrong?
temp08 1-wire configuration
Moderator: RDNZL
- RDNZL
Re: temp08 1-wire configuration
The first line with 01 2b... looks incomplete.
Did you reset it to factory settings?
http://domotiga.nl/projects/domotiga/wi ... tup-TEMP08
Try in a terminal program on correct baud.
After that you should get these type of lines in your terminal every minute: (from onboard 1-wire sensor)
Reading Sensors...
Voltage #1[4D0000004FC78A26]=00.60V 04.98V
Temp #1[4D0000004FC78A26]=24.31C
Regards, Ron.
it's fixed now, as far as I can see this happened when the module is activated and using the serial monitor at the same time
