Support for GreenWave PowerNode
Moderator: RDNZL
Re: Support for GreenWave PowerNode
This week i will have a look at reading the other 5 instances (I also got a GreenWave 6 port device), because the latest r579 seems to getting slighlty more stable with the configs. Possible i need to switch from dynamic requests to explicit Meter requests (code is already partially in the wrapper - but can't accessed by the GUI yet).
ok, found something that delays the query. With the new code it tries to query the indicator, which isn't in the list of supported command classes of the GreenWave. I think just with luck, it worked in the previous version (we get an answer - but looks to be "useless").
To "fix" it, modify "~/domotiga/wrappers/domozwave/open-zwave/config/greenwave/powernode6.xml" and replace it with:
<?xml version="1.0" encoding="utf-8"?>
<Product xmlns='http://code.google.com/p/open-zwave/'>
<CommandClass id="96" mapping="endpoints" />
<!-- COMMAND_CLASS_ALARM. This class is in the list reported by the GreenWave PowerNode 6, but it does not respond to requests -->
<CommandClass id="113" action="remove" />
<!-- COMMAND_CLASS_INDICTATOR. This class is in the list reported by the GreenWave PowerNode 6, but it does not respond to requests -->
<CommandClass id="135" action="remove" />
</Product>
</Product>
Ok, updated configuration files are submitted:
http://code.google.com/p/open-zwave/iss ... ail?id=121
This new configuration also makes it possible to configure the annoying blinking light ... i set it to 255 minutes now
