Thecus 5550
Moderator: RDNZL
Thecus 5550
Postby FoRMaTC » Mon Aug 20, 2012 8:21 pm
FYI:
Recently I bought a Thecus 5550 from Ibood (NAS, Atom processor with 2gb memory) and i'm trying to make some modules to get domotiga up and running on this box.
Cheers,
Bjorn
FoRMaTC
Re: Thecus 5550
Postby uAlex73 » Tue Aug 21, 2012 7:57 am
That it is has an Atom and 2GB of memory, isn't enough to run DomotiGa. Most importantly, can it run gambas? Gambas requires libtool 2.x and most NAS devices based on busybox only support 1.5 (like Synology).
uAlex73
Re: Thecus 5550
Postby FoRMaTC » Tue Aug 21, 2012 7:24 pm
Ive got it almost running now, at least it is moaning about that it can't find the database.
Why isn't the machine powerfull enough?
It runs on a raspberry :)
FoRMaTC
Re: Thecus 5550
Postby FoRMaTC » Tue Aug 21, 2012 9:29 pm
NAS:~/domotiga# ./DomotiGaServer.gambas -a
2012/08/21 22:26:18 Found broadcast address '192.168.1.255'
2012/08/21 22:26:18 ---- Program Restart ----
2012/08/21 22:26:18 Starting DomotiGaServer V0.1.209 last updated on 2012-08-21 at 21:57:03
2012/08/21 22:26:18 Running on host 'NAS' (pid 24937) as user 'root' (id 0) with language en_US.UTF-8
2012/08/21 22:26:18 Program base directory is '/root/domotiga'.
2012/08/21 22:26:18 Database settings are loaded from 'server-domotiga.conf'.
2012/08/21 22:26:18 Active logfiles are 'server-main-2012-08.log', 'server-speak-2012-08.log' and 'server-debug-2012-08.log'.
2012/08/21 22:26:18 Running on Gambas version 2.24.0
2012/08/21 22:26:18 Server uptime is 22:26:18 up 1:01, load average: 0.06, 0.09, 0.18
2012/08/21 22:26:18 Checking directory structure ...
2012/08/21 22:26:18 Connecting to database ...
2012/08/21 22:26:18 Loading modules ...
2012/08/21 22:26:18 Starting setup ...
It runs, doesn't say how but it runs :-)
I'm now going to move the rfxcom and opentherm gateway to the NAS and see how it is performing
FoRMaTC
Re: Thecus 5550
Postby hapklaar » Tue Jan 20, 2015 10:19 am
Hi FoRMaTC,
Really curious if you got this working. I have a Thecus N5550 and am looking to run monitoring software for Plugwise on it.
regards,
Erwin
hapklaar
Return to DomotiGa Forum
cron
