Raspberry pi
Moderator: RDNZL
Re: Raspberry pi
I have updated Domotiga to the latstest version (1.0.000) and it is working real good.
In the previous version I had problems with running the DomotiGApp on my android phone (it crashed upon start). But in this new version it is working quite smoothly.
So thumbs up for this new version!
Pendul
Pendul
Re: Raspberry pi
I am going to update the raspberry this weekend. Will let you know the progress.
Homeseer 3 Pro on Windows 10 / Zwave
Edwin.
Edwin.
Re: Raspberry pi
If you're running an older version of the Raspbian images from the Foundation download page, this command makes the modifications to match the latest release:
sudo apt-get update && sudo apt-get install raspberrypi* raspi-config
(more info can be found here: http://www.raspberrypi.org/phpBB3/viewt ... 8&p=176847)
Which I did because I still used the previous version from august
However my system became unstable. I think it has something to do with the USB-bus again (see also my previous post). Some usb-hubs are interfering with the internal usb-hub of the raspberry.
So I did an system upgrade:
sudo apt-get dist-upgrade
This seems to solve my problems (my system is stable again for whole evening), but I will get you posted
The main message is: be careful with upgrading, especially if you are using an usb-hub.
Pendul
Pendul
Re: Raspberry pi
Installled the new version of Domotiga. Everything seems to work ok.pleaseask wrote:I am going to update the raspberry this weekend. Will let you know the progress.
The Bug in the RFXcom commander is solved.
Edwin.
Edwin.
Re: Raspberry pi
I have a problem with the android client. When I did a clean install everything works as it should with the default database. But when I do a clean install install I can not connect to the android client. The web client works as usual. Sometimes I can obtain the message that there is no connection to the database can be made.
How can I fix this?
How can I fix this?
- Starting Member
Re: Raspberry pi
I have installed the new version of Domotiga.
when i try to installed the z-wave plugin, i have the message : make: *** [libdomozwave.so] Erreur 1 . (when i make "DomoZWave wrapper")
tanks for your help,
Re: Raspberry pi
This is the only error message you get? I would expect more error output.
Re: Raspberry pi now with 512 MB RAM
I'm very interested in the combination Domotiga + Raspberry pi to replace my current Homeseer setup. Although I'm new to Domotiga & relative new to Linux as well, I ordered last week a Raspberry pi B board. Today I noticed they are now shipped with 512 MB RAM on-board ! I guess that can help running the server + web-server on one board.
http://www.raspberrypi.org/archives/2180
Bernard
- RDNZL
Re: Raspberry pi
Let me know how long it took upon receiving it after ordering, and how it works, I still don't have a Raspberry Pi myself
Regards, Ron.
Re: Raspberry pi
I myself tried running domotiga on the rpi, however i ran into an issue with the ftdi driver.
This is used for the rfxcom device. It causes the internal usb hub to become unstable.
See the following thread for more info: http://www.raspberrypi.org/phpBB3/viewt ... =44&t=8010
I have know blacklisted the driver on my rpi and setup usbip to forward the usb devices.
Re: Raspberry pi
Hi ,
I was wondering how do you blacklist the FTDI driver? and how do i install the usbip driver(i am still learning how to use linux)
And how is your RFXcom usb device working.. without any problem?
Edwin.
Edwin.
Re: Raspberry pi
r.koens wrote:I myself tried running domotiga on the rpi, however i ran into an issue with the ftdi driver.
I have more or less the same problem. My system was pretty stable until I did a dist-upgrade. Since that time the raspberry pi freezes every 12 to 24 hours. I already had the feeling that it had something to to with the rfxcom, but now we can look for a possible solution.
Speaking of which: in forum thread of the raspberry pi forum somebody suggested to add dwc_otg.fiq_fix_enable=0 to /boot/cmdline.txt. Does anybody knows what this will do.
Hopefully we can get it stable again otherwise Raspberry Pi and Domotiga will not do for me
@pleaseask: you can blacklist modules here: /etc/modprobe.d/raspi-blacklist.conf.
Pendul
Re: Raspberry pi
@Pendul, any updates on this?
I have also the same problem
Re: Raspberry pi
A quick update on my problems with the raspberry pi:
I found this blog on the internet: http://permalink.gmane.org/gmane.comp.f ... devel/9845
The suggestion is to disabling eth0 and use a wireless usb stick instead.
So I got a Netgear N150. Other USB WiFi Adapters are also possible; just check the list on http://elinux.org. (http://elinux.org/RPi_VerifiedPeriphera ... i_Adapters).
I switch off eth0 using this script: http://www.raspberrypi.org/phpBB3/viewt ... e+ethernet
The system is stable since Monday so I keep my fingers crossed!
Pendul
Pendul
