I've been playing (or at the very least trying to play) with the Domotiga xml-rpc interface from my favourite programming language Ruby.
This was initially not straightforward, as everything I tried led to error messages back from Domotiga.
It turns out that the standard header from the ruby xmlrpc library is
Header ->{"User-Agent"=>"XMLRPC::Client (Ruby 1.9.3)", "Content-Type"=>"text/xml; charset=utf-8", "Content-Length"=>"202"}
and Domotiga (or gambas I guess) does not recognise this and gives the error message :
" HTTP-Error: 415 Unsupported Media Type (RuntimeError)"
To make a long story short - if I remove the "charset+utf-8" bit from the Content-Type field everything works as the header is now :
Header ->{"User-Agent"=>"XMLRPC::Client (Ruby 1.9.3)", "Content-Type"=>"text/xml", "Content-Length"=>"100", "Connection"=>"keep-alive"}
Hope this can help others.
Domotiga xml-rpc anomalies with ruby libraries
Moderator: RDNZL
Re: Domotiga xml-rpc anomalies with ruby libraries
I think this question is answered now in: http://www.domotiga.nl/boards/1/topics/705 ?
If you define text/xml, the charset has to be inside the XML request, not in the HTTP header. Thus DomotiGa XMLRPC (from gambas) is working fine.
The statement here was not really if the XMLRPC implementation was working correctly or not, rather about documenting a problem accessing domotiga from the standard Ruby libraries - I never stated that the Gambas XMLRPC was not working.
But even if we agree that the Gambas XMLRPC is working fine - it would help interoperability if Gambas XMLRPC did check for the presence of "Content-Type"=>"text/xml" within the header string, and ignored the extra charset field, and that would only be good programming practice.
Occasionally we have to take into account that not all implementations of a protocol are 100% compliant and add this to our software, maybe this could be one of those cases? Or is my documentation of the problem (and cause) enough?
I would recommend to report it as bug/feature with gambas (http://gambas.sourceforge.net/).
