$ cd ~/domotiga/wrappers/domozwave
$ ln -s ~/install/open-zwave-read-only ./open-zwave
$ make
g++ -c -Wall -Wno-format -g -DDEBUG -fPIC -I open-zwave/cpp/src -I open-zwave/cpp/src/command_classes/ -I open-zwave/cpp/src/value_classes/ -I open-zwave/cpp/src/platform/ -I open-zwave/cpp/tinyxml/ -I open-zwave/cpp/build/linux/ -I default/ -o DomoZWave.o DomoZWave.cpp
DomoZWave.cpp: In function ‘void OnNotification(const OpenZWave::Notification*, void*)’:
DomoZWave.cpp:1437:8: error: ‘Type_MsgComplete’ is not a member of ‘OpenZWave::Notification’
DomoZWave.cpp:1462:8: error: ‘Type_Error’ is not a member of ‘OpenZWave::Notification’
DomoZWave.cpp:1465:64: error: ‘const class OpenZWave::Notification’ has no member named ‘GetErrorCode’
DomoZWave.cpp: In function ‘const char* DomoZWave_GetDriverStatistics(int32)’:
DomoZWave.cpp:3227:79: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_SOFCnt’
DomoZWave.cpp:3227:94: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_ACKWaiting’
DomoZWave.cpp:3227:113: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_readAborts’
DomoZWave.cpp:3227:132: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_badChecksum’
DomoZWave.cpp:3227:152: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_readCnt’
DomoZWave.cpp:3227:168: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_writeCnt’
DomoZWave.cpp:3227:185: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_CANCnt’
DomoZWave.cpp:3227:200: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_NAKCnt’
DomoZWave.cpp:3227:215: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_ACKCnt’
DomoZWave.cpp:3227:230: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_OOFCnt’
DomoZWave.cpp:3227:245: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_dropped’
DomoZWave.cpp:3227:261: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_retries’
DomoZWave.cpp:3227:277: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_controllerReadCnt’
DomoZWave.cpp:3227:303: error: ‘struct OpenZWave::Driver::DriverData’ has no member named ‘s_controllerWriteCnt’
make: *** [DomoZWave.o] Error 1
Thanks
James
