Very long polling with Plugwise devices
Moderator: RDNZL
Postby Sol-R » Sun Dec 16, 2012 12:48 am
I use 9 plugwise devices (1 circle + and 8 circles) to check power consumption.
Every 5 minutes, Domotiga check the status of each Plugwise device. In my case, this takes about 35 seconds during which any action is impossible. The application is completely frozen. :|
Do you see the same things with Domotiga and Plugwise?
Could it come from the firmware?
Below, you can see the logs of a query sequence of my Plugwise devices.
Thank you for your help.
Sol-R.
2012/12/16 00:13:42 [Plugwise] Checking power usage of device 'Informatique' with address 000D6F0001A44F76
2012/12/16 00:13:42 [Plugwise] Calibration Request
2012/12/16 00:13:42 [Plugwise] MAC: 000D6F0001A44F76
2012/12/16 00:13:42 [Plugwise] String: 0026000D6F0001A44F76 CRC: D867
2012/12/16 00:13:42 [Plugwise] Write: 0026000D6F0001A44F76D867
2012/12/16 00:13:43 [Plugwise] Write: 0026000D6F0001A44F76D867
2012/12/16 00:13:44 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:44 [Plugwise] Data wrong: 000022E500C19E33
▒002722E5000D6F0001A44F763F7D6492B4DA75EB3D42E715000000005A8F
000022E600C170E1
▒002722E6000D6F0001A44F763F7D6492B4DA75EB3D42E715000000008D02
000022E700C1DAB0
▒002722E7000D6F0001A44F763F7D6492B4DA75EB3D42E715000000003066
2012/12/16 00:13:44 [Plugwise] Data correct: 000022E500C19E33
000022E600C170E1
000022E700C1DAB0
000022E800C1BF49
▒002722E8000D6F0001A44F763F7D6492B4DA75EB3D42E7150000000089BC
2012/12/16 00:13:44 [Plugwise] GetCalibration Result: 002722E5000D6F0001A44F763F7D6492B4DA75EB3D42E715000000005A8F
000022E600C170E1
2012/12/16 00:13:44 [Plugwise] Sequence Number: 22E5
2012/12/16 00:13:44 [Plugwise] GainA: 0.989815831184
2012/12/16 00:13:44 [Plugwise] GainB: -4.069146086749E-7
2012/12/16 00:13:44 [Plugwise] OffTot: 0.047583658248
2012/12/16 00:13:44 [Plugwise] OffNoise: 5.877471754111E-39
2012/12/16 00:13:44 [Plugwise] Write: 0012000D6F0001A44F769B9D
2012/12/16 00:13:45 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:45 [Plugwise] Data wrong: 000022E900C11518
▒001322E9000D6F0001A44F7600250124000061610000000000096BBF
000022EA00C10AB3
▒001322EA000D6F0001A44F76002501240000616100000000000960D1
000022EB00C1E461
▒001322EB000D6F0001A44F7600250124000061610000000000090C95
2012/12/16 00:13:45 [Plugwise] Data correct: 000022E900C11518
000022EA00C10AB3
000022EB00C1E461
000022EC00C14E30
▒001322EC000D6F0001A44F760024012400006185000000000010DABB
2012/12/16 00:13:45 [Plugwise] GetPowerInfo Result: 001322E9000D6F0001A44F7600250124000061610000000000096BBF
2012/12/16 00:13:45 [Plugwise] Sequence Number: 22E9
2012/12/16 00:13:45 [Plugwise] Pulses: 0025 (hex) 37
2012/12/16 00:13:45 [Plugwise] Corrected Pulses: 36.670212345971
2012/12/16 00:13:45 [Plugwise] kWh: 0.07819833696
2012/12/16 00:13:45 [Plugwise] Watt: 78.198336960483
2012/12/16 00:13:45 [Plugwise] Checking relay state of device 'Informatique' with address 000D6F0001A44F76
2012/12/16 00:13:45 [Plugwise] MAC: 000D6F0001A44F76
2012/12/16 00:13:45 [Plugwise] String: 0023000D6F0001A44F76 CRC: 8B0D
2012/12/16 00:13:45 [Plugwise] Write: 0023000D6F0001A44F768B0D
2012/12/16 00:13:46 [Plugwise] Write: 0023000D6F0001A44F768B0D
2012/12/16 00:13:46 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:46 [Plugwise] Data wrong: 000022ED00C129E4
# APSRequestNodeInfo: Source MAC: 000D6F0001A5A045# APSRequestNodeInfo: Destination MAC:
000D6F0001A44F76
▒002422ED000D6F0001A44F760C0C542F000479E801856539090087044E0843A901203B
000022EE00C183B5
000D6F0001A44F76
▒002422EE000D6F0001A44F760C0C542F000479E801856539090087044E0843A9018565
000022EF00C16D67
000D6F0001A44F76
▒002422EF000D6F0001A44F760C0C542F000479E801856539090087044E0843A9017AA6
2012/12/16 00:13:46 [Plugwise] Data correct: 000022ED00C129E4
000D6F0001A44F76
000022EE00C183B5
000D6F0001A44F76
000022EF00C16D67
000D6F0001A44F76
000022F000C17384
000D6F0001A44F76
▒002422F0000D6F0001A44F760C0C542F000479E801856539090087044E0843A901A7E5
2012/12/16 00:13:46 [Plugwise] GetDeviceInfo Result: 22ED000D6F0001A44F760C0C542F000479E801856539090087044E0843A9
2012/12/16 00:13:46 [Plugwise] MAC Address: 000D6F0001A44F76
2012/12/16 00:13:46 [Plugwise] Sequence Number: 22ED
2012/12/16 00:13:46 [Plugwise] Log Address: 463 (000479E8)
2012/12/16 00:13:46 [Plugwise] Time in Circle: 3084 12 21551
2012/12/16 00:13:46 [Plugwise] Frequency: 50Hz
2012/12/16 00:13:46 [Plugwise] Hardware version: 6539-0900-8704
2012/12/16 00:13:46 [Plugwise] Firmware: 2011/06/27 08:47:37
2012/12/16 00:13:46 [Plugwise] RelayState: 01 On
2012/12/16 00:13:46 [Plugwise] Checking power usage of device 'Four Micro-ondes' with address 000D6F0000B83184
2012/12/16 00:13:46 [Plugwise] Calibration Request
2012/12/16 00:13:46 [Plugwise] MAC: 000D6F0000B83184
2012/12/16 00:13:46 [Plugwise] String: 0026000D6F0000B83184 CRC: 1904
2012/12/16 00:13:46 [Plugwise] Write: 0026000D6F0000B831841904
2012/12/16 00:13:47 [Plugwise] Write: 0026000D6F0000B831841904
2012/12/16 00:13:47 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:47 [Plugwise] Data wrong: 000022F100C1D9D5
▒002722F1000D6F0000B831843F7F2297B6167DBC3D8738130000000035AF
000022F200C13707
▒002722F2000D6F0000B831843F7F2297B6167DBC3D87381300000000E222
000022F300C19D56
▒002722F3000D6F0000B831843F7F2297B6167DBC3D873813000000005F46
2012/12/16 00:13:47 [Plugwise] Data correct: 000022F100C1D9D5
000022F200C13707
000022F300C19D56
000022F400C1FA82
▒002722F4000D6F0000B831843F7F2297B6167DBC3D873813000000005D19
2012/12/16 00:13:47 [Plugwise] GetCalibration Result: 002722F1000D6F0000B831843F7F2297B6167DBC3D8738130000000035AF
000022F200C13707
2012/12/16 00:13:47 [Plugwise] Sequence Number: 22F1
2012/12/16 00:13:47 [Plugwise] GainA: 0.996621549129
2012/12/16 00:13:47 [Plugwise] GainB: -2.242492882942E-6
2012/12/16 00:13:47 [Plugwise] OffTot: 0.066024921834
2012/12/16 00:13:47 [Plugwise] OffNoise: 5.877471754111E-39
2012/12/16 00:13:47 [Plugwise] Write: 0012000D6F0000B831845AFE
2012/12/16 00:13:48 [Plugwise] Write: 0012000D6F0000B831845AFE
2012/12/16 00:13:49 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:49 [Plugwise] Data wrong: 000022F500C150D3
▒001322F5000D6F0000B83184000100070000021300000000001094B3
000022F600C1BE01
▒001322F6000D6F0000B831840001000700000213000000000010F8F7
000022F700C11450
▒001322F7000D6F0000B8318400010007000002130000000000102CD4
2012/12/16 00:13:49 [Plugwise] Data correct: 000022F500C150D3
000022F600C1BE01
000022F700C11450
000022F800C171A9
▒001322F8000D6F0000B83184000100070000021400000000000D268B
2012/12/16 00:13:49 [Plugwise] GetPowerInfo Result: 001322F5000D6F0000B83184000100070000021300000000001094B3
2012/12/16 00:13:49 [Plugwise] Sequence Number: 22F5
2012/12/16 00:13:49 [Plugwise] Pulses: 0001 (hex) 1
2012/12/16 00:13:49 [Plugwise] Corrected Pulses: 1.062644228471
2012/12/16 00:13:49 [Plugwise] kWh: 0.002266063001
2012/12/16 00:13:49 [Plugwise] Watt: 2.266063001302
2012/12/16 00:13:49 [Plugwise] Checking relay state of device 'Four Micro-ondes' with address 000D6F0000B83184
2012/12/16 00:13:49 [Plugwise] MAC: 000D6F0000B83184
2012/12/16 00:13:49 [Plugwise] String: 0023000D6F0000B83184 CRC: 4A6E
2012/12/16 00:13:49 [Plugwise] Write: 0023000D6F0000B831844A6E
2012/12/16 00:13:50 [Plugwise] Write: 0023000D6F0000B831844A6E
2012/12/16 00:13:50 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:50 [Plugwise] Data wrong: 000022F900C1DBF8
000D6F0000B83184
▒002422F9000D6F0000B831840C0C542F0004793001856539090088044E0844C202B7AA
000022FA00C1C453
000D6F0000B83184
▒002422FA000D6F0000B831840C0C542F0004793001856539090088044E0844C20222EB
000022FB00C12A81
000D6F0000B83184
▒002422FB000D6F0000B831840C0C542F0004793001856539090088044E0844C202DD28
2012/12/16 00:13:50 [Plugwise] Data correct: 000022F900C1DBF8
000D6F0000B83184
000022FA00C1C453
000D6F0000B83184
000022FB00C12A81
000D6F0000B83184
000022FC00C180D0
000D6F0000B83184
▒002422FC000D6F0000B831840C0C542F0004793001856539090088044E0844C2027876
2012/12/16 00:13:50 [Plugwise] GetDeviceInfo Result: 22F9000D6F0000B831840C0C542F0004793001856539090088044E0844C2
2012/12/16 00:13:50 [Plugwise] MAC Address: 000D6F0000B83184
2012/12/16 00:13:50 [Plugwise] Sequence Number: 22F9
2012/12/16 00:13:50 [Plugwise] Log Address: 457 (00047930)
2012/12/16 00:13:50 [Plugwise] Time in Circle: 3084 12 21551
2012/12/16 00:13:50 [Plugwise] Frequency: 50Hz
2012/12/16 00:13:50 [Plugwise] Hardware version: 6539-0900-8804
2012/12/16 00:13:50 [Plugwise] Firmware: 2011/06/27 08:52:18
2012/12/16 00:13:50 [Plugwise] RelayState: 01 On
2012/12/16 00:13:50 [Plugwise] Checking power usage of device 'Lampe Salon 1' with address 000D6F0000B7E3EA
2012/12/16 00:13:50 [Plugwise] Calibration Request
2012/12/16 00:13:50 [Plugwise] MAC: 000D6F0000B7E3EA
2012/12/16 00:13:50 [Plugwise] String: 0026000D6F0000B7E3EA CRC: 2746
2012/12/16 00:13:50 [Plugwise] Write: 0026000D6F0000B7E3EA2746
2012/12/16 00:13:51 [Plugwise] Write: 0026000D6F0000B7E3EA2746
2012/12/16 00:13:51 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:51 [Plugwise] Data wrong: 000022FD00C1E704
▒002722FD000D6F0000B7E3EA3F7DAECFB628B0473D78C33E00000000A82C
000022FE00C14D55
▒002722FE000D6F0000B7E3EA3F7DAECFB628B0473D78C33E000000001548
000022FF00C1A387
▒002722FF000D6F0000B7E3EA3F7DAECFB628B0473D78C33E00000000C2C5
2012/12/16 00:13:51 [Plugwise] Data correct: 000022FD00C1E704
000022FE00C14D55
000022FF00C1A387
0000230000C10398
▒00272300000D6F0000B7E3EA3F7DAECFB628B0473D78C33E00000000F58E
2012/12/16 00:13:51 [Plugwise] GetCalibration Result: 002722FD000D6F0000B7E3EA3F7DAECFB628B0473D78C33E00000000A82C
000022FE00C14D55
2012/12/16 00:13:51 [Plugwise] Sequence Number: 22FD
2012/12/16 00:13:51 [Plugwise] GainA: 0.990948617458
2012/12/16 00:13:51 [Plugwise] GainB: -2.513655772418E-6
2012/12/16 00:13:51 [Plugwise] OffTot: 0.06073307246
2012/12/16 00:13:51 [Plugwise] OffNoise: 5.877471754111E-39
2012/12/16 00:13:51 [Plugwise] Write: 0012000D6F0000B7E3EA64BC
2012/12/16 00:13:52 [Plugwise] Write: 0012000D6F0000B7E3EA64BC
2012/12/16 00:13:53 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:53 [Plugwise] Data wrong: 0000230100C1A9C9
▒00132301000D6F0000B7E3EAFFFFFFFF00000000FFFFFE4F00081DB2
0000230200C1471B
▒00132302000D6F0000B7E3EAFFFFFFFF00000000FFFFFE4F000871F6
0000230300C1ED4A
▒00132303000D6F0000B7E3EAFFFFFFFF00000000FFFFFE4F0008A5D5
2012/12/16 00:13:53 [Plugwise] Data correct: 0000230100C1A9C9
0000230200C1471B
0000230300C1ED4A
0000230400C18A9E
▒00132304000D6F0000B7E3EA0000FFFF00000000FFFFFE4F000F6D85
2012/12/16 00:13:53 [Plugwise] GetPowerInfo Result: 00132301000D6F0000B7E3EAFFFFFFFF00000000FFFFFE4F00081DB2
2012/12/16 00:13:53 [Plugwise] Sequence Number: 2301
2012/12/16 00:13:53 [Plugwise] Pulses: FFFF (hex) -1
2012/12/16 00:13:53 [Plugwise] Corrected Pulses: -0.930218058654
2012/12/16 00:13:53 [Plugwise] kWh: -0.001983667411
2012/12/16 00:13:53 [Plugwise] Watt: -1.983667411334
2012/12/16 00:13:53 [Plugwise] Checking relay state of device 'Lampe Salon 1' with address 000D6F0000B7E3EA
2012/12/16 00:13:53 [Plugwise] MAC: 000D6F0000B7E3EA
2012/12/16 00:13:53 [Plugwise] String: 0023000D6F0000B7E3EA CRC: 742C
2012/12/16 00:13:53 [Plugwise] Write: 0023000D6F0000B7E3EA742C
2012/12/16 00:13:54 [Plugwise] Write: 0023000D6F0000B7E3EA742C
2012/12/16 00:13:54 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:54 [Plugwise] Data wrong: 0000230500C120CF
000D6F0000B7E3EA
▒00242305000D6F0000B7E3EA0C0C542F0004758800856539090088044E0844C202B8BE
0000230600C1CE1D
000D6F0000B7E3EA
▒00242306000D6F0000B7E3EA0C0C542F0004758800856539090088044E0844C202477D
0000230700C1644C
000D6F0000B7E3EA
▒00242307000D6F0000B7E3EA0C0C542F0004758800856539090088044E0844C202E223
2012/12/16 00:13:54 [Plugwise] Data correct: 0000230500C120CF
000D6F0000B7E3EA
0000230600C1CE1D
000D6F0000B7E3EA
0000230700C1644C
000D6F0000B7E3EA
0000230800C101B5
000D6F0000B7E3EA
▒00242308000D6F0000B7E3EA0C0C542F0004758800856539090088044E0844C202D28F
2012/12/16 00:13:54 [Plugwise] GetDeviceInfo Result: 2305000D6F0000B7E3EA0C0C542F0004758800856539090088044E0844C2
2012/12/16 00:13:54 [Plugwise] MAC Address: 000D6F0000B7E3EA
2012/12/16 00:13:54 [Plugwise] Sequence Number: 2305
2012/12/16 00:13:54 [Plugwise] Log Address: 428 (00047588)
2012/12/16 00:13:54 [Plugwise] Time in Circle: 3084 12 21551
2012/12/16 00:13:54 [Plugwise] Frequency: 50Hz
2012/12/16 00:13:54 [Plugwise] Hardware version: 6539-0900-8804
2012/12/16 00:13:54 [Plugwise] Firmware: 2011/06/27 08:52:18
2012/12/16 00:13:54 [Plugwise] RelayState: 00 Off
2012/12/16 00:13:54 [Plugwise] Checking power usage of device 'Lampe Dressing' with address 000D6F00004BC205
2012/12/16 00:13:54 [Plugwise] Calibration Request
2012/12/16 00:13:54 [Plugwise] MAC: 000D6F00004BC205
2012/12/16 00:13:54 [Plugwise] String: 0026000D6F00004BC205 CRC: 08FC
2012/12/16 00:13:54 [Plugwise] Write: 0026000D6F00004BC20508FC
2012/12/16 00:13:55 [Plugwise] Write: 0026000D6F00004BC20508FC
2012/12/16 00:13:55 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:55 [Plugwise] Data wrong: 0000230900C1ABE4
▒00272309000D6F00004BC2053F7ECD4434118FD83C8AB82700000000A309
0000230A00C1B44F
▒0027230A000D6F00004BC2053F7ECD4434118FD83C8AB827000000003D7C
0000230B00C15A9D
▒0027230B000D6F00004BC2053F7ECD4434118FD83C8AB82700000000EAF1
2012/12/16 00:13:55 [Plugwise] Data correct: 0000230900C1ABE4
0000230A00C1B44F
0000230B00C15A9D
0000230C00C1F0CC
▒0027230C000D6F00004BC2053F7ECD4434118FD83C8AB827000000005795
2012/12/16 00:13:55 [Plugwise] GetCalibration Result: 00272309000D6F00004BC2053F7ECD4434118FD83C8AB82700000000A309
0000230A00C1B44F
2012/12/16 00:13:55 [Plugwise] Sequence Number: 2309
2012/12/16 00:13:55 [Plugwise] GainA: 0.995319604874
2012/12/16 00:13:55 [Plugwise] GainB: 1.355650738333E-7
2012/12/16 00:13:55 [Plugwise] OffTot: 0.016933513805
2012/12/16 00:13:55 [Plugwise] OffNoise: 5.877471754111E-39
2012/12/16 00:13:55 [Plugwise] Write: 0012000D6F00004BC2054B06
2012/12/16 00:13:56 [Plugwise] Write: 0012000D6F00004BC2054B06
2012/12/16 00:13:57 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:57 [Plugwise] Data wrong: 0000230D00C19718
▒0013230D000D6F00004BC2050000000000000000FFFFFDD4000AB5CB
0000230E00C13D49
▒0013230E000D6F00004BC2050000000000000000FFFFFDD4000A61E8
0000230F00C1D39B
▒0013230F000D6F00004BC2050000000000000000FFFFFDD4000A0DAC
2012/12/16 00:13:57 [Plugwise] Data correct: 0000230D00C19718
0000230E00C13D49
0000230F00C1D39B
0000231000C14638
▒00132310000D6F00004BC2050000000000000000FFFFFDD40002F999
2012/12/16 00:13:57 [Plugwise] GetPowerInfo Result: 0013230D000D6F00004BC2050000000000000000FFFFFDD4000AB5CB
2012/12/16 00:13:57 [Plugwise] Sequence Number: 230D
2012/12/16 00:13:57 [Plugwise] Pulses: 0000 (hex) 0
2012/12/16 00:13:57 [Plugwise] Corrected Pulses: 0
2012/12/16 00:13:57 [Plugwise] kWh: 0
2012/12/16 00:13:57 [Plugwise] Watt: 0
2012/12/16 00:13:57 [Plugwise] Checking relay state of device 'Lampe Dressing' with address 000D6F00004BC205
2012/12/16 00:13:57 [Plugwise] MAC: 000D6F00004BC205
2012/12/16 00:13:57 [Plugwise] String: 0023000D6F00004BC205 CRC: 5B96
2012/12/16 00:13:57 [Plugwise] Write: 0023000D6F00004BC2055B96
2012/12/16 00:13:58 [Plugwise] Write: 0023000D6F00004BC2055B96
2012/12/16 00:13:58 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:58 [Plugwise] Data wrong: 0000231100C1EC69
000D6F00004BC205
▒00242311000D6F00004BC2050C0C542F0004790000856539090088044E0844C2021EAA
0000231200C102BB
000D6F00004BC205
▒00242312000D6F00004BC2050C0C542F0004790000856539090088044E0844C202E169
0000231300C1A8EA
000D6F00004BC205
▒00242313000D6F00004BC2050C0C542F0004790000856539090088044E0844C2024437
2012/12/16 00:13:58 [Plugwise] Data correct: 0000231100C1EC69
000D6F00004BC205
0000231200C102BB
000D6F00004BC205
0000231300C1A8EA
000D6F00004BC205
0000231400C1CF3E
000D6F00004BC205
▒00242314000D6F00004BC2050C0C542F0004790000856539090088044E0844C2020ECE
2012/12/16 00:13:58 [Plugwise] GetDeviceInfo Result: 2311000D6F00004BC2050C0C542F0004790000856539090088044E0844C2
2012/12/16 00:13:58 [Plugwise] MAC Address: 000D6F00004BC205
2012/12/16 00:13:58 [Plugwise] Sequence Number: 2311
2012/12/16 00:13:58 [Plugwise] Log Address: 456 (00047900)
2012/12/16 00:13:58 [Plugwise] Time in Circle: 3084 12 21551
2012/12/16 00:13:58 [Plugwise] Frequency: 50Hz
2012/12/16 00:13:58 [Plugwise] Hardware version: 6539-0900-8804
2012/12/16 00:13:58 [Plugwise] Firmware: 2011/06/27 08:52:18
2012/12/16 00:13:58 [Plugwise] RelayState: 00 Off
2012/12/16 00:13:58 [Plugwise] Checking power usage of device 'Frigo' with address 000D6F0000B7E3F1
2012/12/16 00:13:58 [Plugwise] Calibration Request
2012/12/16 00:13:58 [Plugwise] MAC: 000D6F0000B7E3F1
2012/12/16 00:13:58 [Plugwise] String: 0026000D6F0000B7E3F1 CRC: 0C82
2012/12/16 00:13:58 [Plugwise] Write: 0026000D6F0000B7E3F10C82
2012/12/16 00:13:59 [Plugwise] Write: 0026000D6F0000B7E3F10C82
2012/12/16 00:13:59 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:13:59 [Plugwise] Data wrong: 0000231500C1656F
▒00272315000D6F0000B7E3F13F802BBFB617C53F3CBFD83B000000002248
0000231600C18BBD
▒00272316000D6F0000B7E3F13F802BBFB617C53F3CBFD83B00000000F5C5
0000231700C121EC
▒00272317000D6F0000B7E3F13F802BBFB617C53F3CBFD83B0000000048A1
2012/12/16 00:13:59 [Plugwise] Data correct: 0000231500C1656F
0000231600C18BBD
0000231700C121EC
0000231800C14415
▒00272318000D6F0000B7E3F13F802BBFB617C53F3CBFD83B00000000F17B
2012/12/16 00:13:59 [Plugwise] GetCalibration Result: 00272315000D6F0000B7E3F13F802BBFB617C53F3CBFD83B000000002248
0000231600C18BBD
2012/12/16 00:13:59 [Plugwise] Sequence Number: 2315
2012/12/16 00:13:59 [Plugwise] GainA: 1.001335024834
2012/12/16 00:13:59 [Plugwise] GainB: -2.261556574013E-6
2012/12/16 00:13:59 [Plugwise] OffTot: 0.02341853641
2012/12/16 00:13:59 [Plugwise] OffNoise: 5.877471754111E-39
2012/12/16 00:13:59 [Plugwise] Write: 0012000D6F0000B7E3F14F78
2012/12/16 00:14:00 [Plugwise] Write: 0012000D6F0000B7E3F14F78
2012/12/16 00:14:00 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:00 [Plugwise] Data wrong: 0000231900C1EE44
▒00132319000D6F0000B7E3F10000000000000000FFFFFDAA00056481
0000231A00C1F1EF
▒0013231A000D6F0000B7E3F10000000000000000FFFFFDAA00056FEF
0000231B00C11F3D
▒0013231B000D6F0000B7E3F10000000000000000FFFFFDAA000503AB
2012/12/16 00:14:00 [Plugwise] Data correct: 0000231900C1EE44
0000231A00C1F1EF
0000231B00C11F3D
0000231C00C1B56C
▒0013231C000D6F0000B7E3F10000000000000000FFFFFDAA0005D788
2012/12/16 00:14:00 [Plugwise] GetPowerInfo Result: 00132319000D6F0000B7E3F10000000000000000FFFFFDAA00056481
2012/12/16 00:14:00 [Plugwise] Sequence Number: 2319
2012/12/16 00:14:00 [Plugwise] Pulses: 0000 (hex) 0
2012/12/16 00:14:00 [Plugwise] Corrected Pulses: 0
2012/12/16 00:14:00 [Plugwise] kWh: 0
2012/12/16 00:14:00 [Plugwise] Watt: 0
2012/12/16 00:14:00 [Plugwise] Checking relay state of device 'Frigo' with address 000D6F0000B7E3F1
2012/12/16 00:14:00 [Plugwise] MAC: 000D6F0000B7E3F1
2012/12/16 00:14:00 [Plugwise] String: 0023000D6F0000B7E3F1 CRC: 5FE8
2012/12/16 00:14:00 [Plugwise] Write: 0023000D6F0000B7E3F15FE8
2012/12/16 00:14:01 [Plugwise] Write: 0023000D6F0000B7E3F15FE8
2012/12/16 00:14:02 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:02 [Plugwise] Data wrong: 0000231D00C1D2B8
000D6F0000B7E3F1
▒0024231D000D6F0000B7E3F10C0C542F0004792801856539090088044E0844C202E4CE
0000231E00C178E9
000D6F0000B7E3F1
▒0024231E000D6F0000B7E3F10C0C542F0004792801856539090088044E0844C2024190
0000231F00C1963B
000D6F0000B7E3F1
▒0024231F000D6F0000B7E3F10C0C542F0004792801856539090088044E0844C202BE53
2012/12/16 00:14:02 [Plugwise] Data correct: 0000231D00C1D2B8
000D6F0000B7E3F1
0000231E00C178E9
000D6F0000B7E3F1
0000231F00C1963B
000D6F0000B7E3F1
0000232000C188D8
000D6F0000B7E3F1
▒00242320000D6F0000B7E3F10C0C542F0004792801856539090088044E0844C2026310
2012/12/16 00:14:02 [Plugwise] GetDeviceInfo Result: 231D000D6F0000B7E3F10C0C542F0004792801856539090088044E0844C2
2012/12/16 00:14:02 [Plugwise] MAC Address: 000D6F0000B7E3F1
2012/12/16 00:14:02 [Plugwise] Sequence Number: 231D
2012/12/16 00:14:02 [Plugwise] Log Address: 457 (00047928)
2012/12/16 00:14:02 [Plugwise] Time in Circle: 3084 12 21551
2012/12/16 00:14:02 [Plugwise] Frequency: 50Hz
2012/12/16 00:14:02 [Plugwise] Hardware version: 6539-0900-8804
2012/12/16 00:14:02 [Plugwise] Firmware: 2011/06/27 08:52:18
2012/12/16 00:14:02 [Plugwise] RelayState: 01 On
2012/12/16 00:14:02 [Plugwise] Checking power usage of device 'Accessoires Cuisine' with address 000D6F00004BA11D
PuTT2012/12/16 00:14:02 [Plugwise] Calibration Request
Y2012/12/16 00:14:02 [Plugwise] MAC: 000D6F00004BA11D
2012/12/16 00:14:02 [Plugwise] String: 0026000D6F00004BA11D CRC: E143
2012/12/16 00:14:02 [Plugwise] Write: 0026000D6F00004BA11DE143
2012/12/16 00:14:03 [Plugwise] Write: 0026000D6F00004BA11DE143
2012/12/16 00:14:03 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:03 [Plugwise] Data wrong: 0000232100C12289
▒00272321000D6F00004BA11D3F7C3270338A5AEA3D4FA458000000000C3A
0000232200C1CC5B
▒00272322000D6F00004BA11D3F7C3270338A5AEA3D4FA45800000000DBB7
0000232300C1660A
▒00272323000D6F00004BA11D3F7C3270338A5AEA3D4FA4580000000066D3
2012/12/16 00:14:03 [Plugwise] Data correct: 0000232100C12289
0000232200C1CC5B
0000232300C1660A
0000232400C101DE
▒00272324000D6F00004BA11D3F7C3270338A5AEA3D4FA45800000000648C
2012/12/16 00:14:03 [Plugwise] GetCalibration Result: 00272321000D6F00004BA11D3F7C3270338A5AEA3D4FA458000000000C3A
0000232200C1CC5B
2012/12/16 00:14:03 [Plugwise] Sequence Number: 2321
2012/12/16 00:14:03 [Plugwise] GainA: 0.985144615173
2012/12/16 00:14:03 [Plugwise] GainB: 6.442662936479E-8
2012/12/16 00:14:03 [Plugwise] OffTot: 0.050693839788
2012/12/16 00:14:03 [Plugwise] OffNoise: 5.877471754111E-39
2012/12/16 00:14:03 [Plugwise] Write: 0012000D6F00004BA11DA2B9
2012/12/16 00:14:04 [Plugwise] Write: 0012000D6F00004BA11DA2B9
2012/12/16 00:14:04 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:04 [Plugwise] Data wrong: 0000232500C1AB8F
▒00132325000D6F00004BA11D00000002000000B900000000000DF981
0000232600C1455D
▒00132326000D6F00004BA11D00000002000000B900000000000D95C5
0000232700C1EF0C
▒00132327000D6F00004BA11D00000002000000B900000000000D41E6
2012/12/16 00:14:04 [Plugwise] Data correct: 0000232500C1AB8F
0000232600C1455D
0000232700C1EF0C
0000232800C18AF5
▒00132328000D6F00004BA11D00010002000000BA000000000007ED85
2012/12/16 00:14:04 [Plugwise] GetPowerInfo Result: 00132325000D6F00004BA11D00000002000000B900000000000DF981
2012/12/16 00:14:04 [Plugwise] Sequence Number: 2325
2012/12/16 00:14:04 [Plugwise] Pulses: 0000 (hex) 0
2012/12/16 00:14:04 [Plugwise] Corrected Pulses: 0
2012/12/16 00:14:04 [Plugwise] kWh: 0
2012/12/16 00:14:04 [Plugwise] Watt: 0
2012/12/16 00:14:04 [Plugwise] Checking relay state of device 'Accessoires Cuisine' with address 000D6F00004BA11D
2012/12/16 00:14:04 [Plugwise] MAC: 000D6F00004BA11D
2012/12/16 00:14:04 [Plugwise] String: 0023000D6F00004BA11D CRC: B229
2012/12/16 00:14:04 [Plugwise] Write: 0023000D6F00004BA11DB229
2012/12/16 00:14:05 [Plugwise] Write: 0023000D6F00004BA11DB229
2012/12/16 00:14:06 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:06 [Plugwise] Data wrong: 0000232900C120A4
000D6F00004BA11D
▒00242329000D6F00004BA11D0C0C542F0004793001856539090088044E0844C202C886
0000232A00C13F0F
000D6F00004BA11D
▒0024232A000D6F00004BA11D0C0C542F0004793001856539090088044E0844C2025DC7
0000232B00C1D1DD
000D6F00004BA11D
▒0024232B000D6F00004BA11D0C0C542F0004793001856539090088044E0844C202A204
2012/12/16 00:14:06 [Plugwise] Data correct: 0000232900C120A4
000D6F00004BA11D
0000232A00C13F0F
000D6F00004BA11D
0000232B00C1D1DD
000D6F00004BA11D
0000232C00C17B8C
000D6F00004BA11D
▒0024232C000D6F00004BA11D0C0C542F0004793001856539090088044E0844C202075A
2012/12/16 00:14:06 [Plugwise] GetDeviceInfo Result: 2329000D6F00004BA11D0C0C542F0004793001856539090088044E0844C2
2012/12/16 00:14:06 [Plugwise] MAC Address: 000D6F00004BA11D
2012/12/16 00:14:06 [Plugwise] Sequence Number: 2329
2012/12/16 00:14:06 [Plugwise] Log Address: 457 (00047930)
2012/12/16 00:14:06 [Plugwise] Time in Circle: 3084 12 21551
2012/12/16 00:14:06 [Plugwise] Frequency: 50Hz
2012/12/16 00:14:06 [Plugwise] Hardware version: 6539-0900-8804
2012/12/16 00:14:06 [Plugwise] Firmware: 2011/06/27 08:52:18
2012/12/16 00:14:06 [Plugwise] RelayState: 01 On
2012/12/16 00:14:06 [Plugwise] Checking power usage of device 'Lampe Salon 2' with address 000D6F0000D31ABC
2012/12/16 00:14:06 [Plugwise] Calibration Request
2012/12/16 00:14:06 [Plugwise] MAC: 000D6F0000D31ABC
2012/12/16 00:14:06 [Plugwise] String: 0026000D6F0000D31ABC CRC: A498
2012/12/16 00:14:06 [Plugwise] Write: 0026000D6F0000D31ABCA498
2012/12/16 00:14:07 [Plugwise] Write: 0026000D6F0000D31ABCA498
2012/12/16 00:14:07 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:07 [Plugwise] Data wrong: 0000232D00C11C58
▒0027232D000D6F0000D31ABC3F7EB857B6229CCF3D5F88A500000000FDD0
0000232E00C1B609
▒0027232E000D6F0000D31ABC3F7EB857B6229CCF3D5F88A50000000040B4
0000232F00C158DB
▒0027232F000D6F0000D31ABC3F7EB857B6229CCF3D5F88A5000000009739
2012/12/16 00:14:07 [Plugwise] Data correct: 0000232D00C11C58
0000232E00C1B609
0000232F00C158DB
0000233000C1CD78
▒00272330000D6F0000D31ABC3F7EB857B6229CCF3D5F88A5000000001F84
2012/12/16 00:14:07 [Plugwise] GetCalibration Result: 0027232D000D6F0000D31ABC3F7EB857B6229CCF3D5F88A500000000FDD0
0000232E00C1B609
2012/12/16 00:14:07 [Plugwise] Sequence Number: 232D
2012/12/16 00:14:07 [Plugwise] GainA: 0.995000302792
2012/12/16 00:14:07 [Plugwise] GainB: -2.423115574857E-6
2012/12/16 00:14:07 [Plugwise] OffTot: 0.054573673755
2012/12/16 00:14:07 [Plugwise] OffNoise: 5.877471754111E-39
2012/12/16 00:14:07 [Plugwise] Write: 0012000D6F0000D31ABCE762
2012/12/16 00:14:08 [Plugwise] Write: 0012000D6F0000D31ABCE762
2012/12/16 00:14:08 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:08 [Plugwise] Data wrong: 0000233100C16729
▒00132331000D6F0000D31ABC0000000000000000FFFFFF06000DC9FC
0000233200C189FB
▒00132332000D6F0000D31ABC0000000000000000FFFFFF060006FB6D
0000233300C123AA
▒00132333000D6F0000D31ABC0000000000000000FFFFFF0600062F4E
2012/12/16 00:14:08 [Plugwise] Data correct: 0000233100C16729
0000233200C189FB
0000233300C123AA
0000233400C1447E
▒00132334000D6F0000D31ABC0000000000000000FFFFFF06000623E5
2012/12/16 00:14:08 [Plugwise] GetPowerInfo Result: 00132331000D6F0000D31ABC0000000000000000FFFFFF06000DC9FC
2012/12/16 00:14:08 [Plugwise] Sequence Number: 2331
2012/12/16 00:14:08 [Plugwise] Pulses: 0000 (hex) 0
2012/12/16 00:14:08 [Plugwise] Corrected Pulses: 0
2012/12/16 00:14:08 [Plugwise] kWh: 0
2012/12/16 00:14:08 [Plugwise] Watt: 0
2012/12/16 00:14:08 [Plugwise] Checking relay state of device 'Lampe Salon 2' with address 000D6F0000D31ABC
2012/12/16 00:14:08 [Plugwise] MAC: 000D6F0000D31ABC
2012/12/16 00:14:08 [Plugwise] String: 0023000D6F0000D31ABC CRC: F7F2
2012/12/16 00:14:08 [Plugwise] Write: 0023000D6F0000D31ABCF7F2
2012/12/16 00:14:09 [Plugwise] Write: 0023000D6F0000D31ABCF7F2
2012/12/16 00:14:10 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:10 [Plugwise] Data wrong: 0000233500C1EE2F
000D6F0000D31ABC
▒00242335000D6F0000D31ABC0C0C542F0004725800856539090088044E0844C20267D2
0000233600C100FD
000D6F0000D31ABC
▒00242336000D6F0000D31ABC0C0C542F0004725800856539090088044E0844C2029811
0000233700C1AAAC
000D6F0000D31ABC
▒00242337000D6F0000D31ABC0C0C542F0004725800856539090088044E0844C2023D4F
2012/12/16 00:14:10 [Plugwise] Data correct: 0000233500C1EE2F
000D6F0000D31ABC
0000233600C100FD
000D6F0000D31ABC
0000233700C1AAAC
000D6F0000D31ABC
0000233800C1CF55
000D6F0000D31ABC
▒00242338000D6F0000D31ABC0C0C542F0004725800856539090088044E0844C2020DE3
2012/12/16 00:14:10 [Plugwise] GetDeviceInfo Result: 2335000D6F0000D31ABC0C0C542F0004725800856539090088044E0844C2
2012/12/16 00:14:10 [Plugwise] MAC Address: 000D6F0000D31ABC
2012/12/16 00:14:10 [Plugwise] Sequence Number: 2335
2012/12/16 00:14:10 [Plugwise] Log Address: 402 (00047258)
2012/12/16 00:14:10 [Plugwise] Time in Circle: 3084 12 21551
2012/12/16 00:14:10 [Plugwise] Frequency: 50Hz
2012/12/16 00:14:10 [Plugwise] Hardware version: 6539-0900-8804
2012/12/16 00:14:10 [Plugwise] Firmware: 2011/06/27 08:52:18
2012/12/16 00:14:10 [Plugwise] RelayState: 00 Off
2012/12/16 00:14:10 [Plugwise] Checking power usage of device 'Congélateur' with address 000D6F00004BA090
2012/12/16 00:14:10 [Plugwise] Calibration Request
2012/12/16 00:14:10 [Plugwise] MAC: 000D6F00004BA090
2012/12/16 00:14:10 [Plugwise] String: 0026000D6F00004BA090 CRC: 61C9
2012/12/16 00:14:10 [Plugwise] Write: 0026000D6F00004BA09061C9
2012/12/16 00:14:11 [Plugwise] Write: 0026000D6F00004BA09061C9
2012/12/16 00:14:11 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:11 [Plugwise] Data wrong: 0000233900C16504
▒00272339000D6F00004BA0903F7D49F8B62E100B3C072CE0000000001BC0
0000233A00C17AAF
▒0027233A000D6F00004BA0903F7D49F8B62E100B3C072CE00000000085B5
0000233B00C1947D
▒0027233B000D6F00004BA0903F7D49F8B62E100B3C072CE0000000005238
2012/12/16 00:14:11 [Plugwise] Data correct: 0000233900C16504
0000233A00C17AAF
0000233B00C1947D
0000233C00C13E2C
▒0027233C000D6F00004BA0903F7D49F8B62E100B3C072CE000000000EF5C
2012/12/16 00:14:11 [Plugwise] GetCalibration Result: 00272339000D6F00004BA0903F7D49F8B62E100B3C072CE0000000001BC0
0000233A00C17AAF
2012/12/16 00:14:11 [Plugwise] Sequence Number: 2339
2012/12/16 00:14:11 [Plugwise] GainA: 0.989409923553
2012/12/16 00:14:11 [Plugwise] GainB: -2.593735871415E-6
2012/12/16 00:14:11 [Plugwise] OffTot: 0.008250445127
2012/12/16 00:14:11 [Plugwise] OffNoise: 5.877471754111E-39
2012/12/16 00:14:11 [Plugwise] Write: 0012000D6F00004BA0902233
2012/12/16 00:14:12 [Plugwise] Write: 0012000D6F00004BA0902233
2012/12/16 00:14:12 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:12 [Plugwise] Data wrong: 0000233D00C159F8
▒0013233D000D6F00004BA09000200106000025AD00000000000C4C86
0000233E00C1F3A9
▒0013233E000D6F00004BA09000200106000025AD00000000000C98A5
0000233F00C11D7B
▒0013233F000D6F00004BA09000200106000025AD00000000000CF4E1
2012/12/16 00:14:12 [Plugwise] Data correct: 0000233D00C159F8
0000233E00C1F3A9
0000233F00C11D7B
0000234000C10539
▒00132340000D6F00004BA09000210106000025CE0000000000047430
2012/12/16 00:14:12 [Plugwise] GetPowerInfo Result: 0013233D000D6F00004BA09000200106000025AD00000000000C4C86
2012/12/16 00:14:12 [Plugwise] Sequence Number: 233D
2012/12/16 00:14:12 [Plugwise] Pulses: 0020 (hex) 32
2012/12/16 00:14:12 [Plugwise] Corrected Pulses: 31.666712013306
2012/12/16 00:14:12 [Plugwise] kWh: 0.067528494056
2012/12/16 00:14:12 [Plugwise] Watt: 67.52849405627
2012/12/16 00:14:12 [Plugwise] Checking relay state of device 'Congélateur' with address 000D6F00004BA090
2012/12/16 00:14:12 [Plugwise] MAC: 000D6F00004BA090
2012/12/16 00:14:12 [Plugwise] String: 0023000D6F00004BA090 CRC: 32A3
2012/12/16 00:14:12 [Plugwise] Write: 0023000D6F00004BA09032A3
2012/12/16 00:14:13 [Plugwise] Write: 0023000D6F00004BA09032A3
2012/12/16 00:14:13 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:13 [Plugwise] Data wrong: 0000234100C1AF68
000D6F00004BA090
▒00242341000D6F00004BA0900C0C542F00046FA001856539090088044E0844C202A5BA
0000234200C141BA
000D6F00004BA090
▒00242342000D6F00004BA0900C0C542F00046FA001856539090088044E0844C2025A79
0000234300C1EBEB
000D6F00004BA090
▒00242343000D6F00004BA0900C0C542F00046FA001856539090088044E0844C202FF27
2012/12/16 00:14:13 [Plugwise] Data correct: 0000234100C1AF68
000D6F00004BA090
0000234200C141BA
000D6F00004BA090
0000234300C1EBEB
000D6F00004BA090
0000234400C18C3F
000D6F00004BA090
▒00242344000D6F00004BA0900C0C542F00046FA001856539090088044E0844C202B5DE
2012/12/16 00:14:13 [Plugwise] GetDeviceInfo Result: 2341000D6F00004BA0900C0C542F00046FA001856539090088044E0844C2
2012/12/16 00:14:13 [Plugwise] MAC Address: 000D6F00004BA090
2012/12/16 00:14:13 [Plugwise] Sequence Number: 2341
2012/12/16 00:14:13 [Plugwise] Log Address: 381 (00046FA0)
2012/12/16 00:14:13 [Plugwise] Time in Circle: 3084 12 21551
2012/12/16 00:14:13 [Plugwise] Frequency: 50Hz
2012/12/16 00:14:13 [Plugwise] Hardware version: 6539-0900-8804
2012/12/16 00:14:13 [Plugwise] Firmware: 2011/06/27 08:52:18
2012/12/16 00:14:13 [Plugwise] RelayState: 01 On
2012/12/16 00:14:13 [Plugwise] Checking power usage of device 'Four' with address 000D6F00004B9B70
2012/12/16 00:14:13 [Plugwise] Calibration Request
2012/12/16 00:14:13 [Plugwise] MAC: 000D6F00004B9B70
2012/12/16 00:14:13 [Plugwise] String: 0026000D6F00004B9B70 CRC: 3318
2012/12/16 00:14:13 [Plugwise] Write: 0026000D6F00004B9B703318
2012/12/16 00:14:14 [Plugwise] Write: 0026000D6F00004B9B703318
2012/12/16 00:14:15 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:15 [Plugwise] Data wrong: 0000234500C1266E
▒00272345000D6F00004B9B703F81200FB6338CA03D503A9B0000000006C0
0000234600C1C8BC
▒00272346000D6F00004B9B703F81200FB6338CA03D503A9B00000000D14D
0000234700C162ED
▒00272347000D6F00004B9B703F81200FB6338CA03D503A9B000000006C29
2012/12/16 00:14:15 [Plugwise] Data correct: 0000234500C1266E
0000234600C1C8BC
0000234700C162ED
0000234800C10714
▒00272348000D6F00004B9B703F81200FB6338CA03D503A9B00000000D5F3
2012/12/16 00:14:15 [Plugwise] GetCalibration Result: 00272345000D6F00004B9B703F81200FB6338CA03D503A9B0000000006C0
0000234600C1C8BC
2012/12/16 00:14:15 [Plugwise] Sequence Number: 2345
2012/12/16 00:14:15 [Plugwise] GainA: 1.008790850639
2012/12/16 00:14:15 [Plugwise] GainB: -2.675493306015E-6
2012/12/16 00:14:15 [Plugwise] OffTot: 0.05083714053
2012/12/16 00:14:15 [Plugwise] OffNoise: 5.877471754111E-39
2012/12/16 00:14:15 [Plugwise] Write: 0012000D6F00004B9B7070E2
2012/12/16 00:14:16 [Plugwise] Write: 0012000D6F00004B9B7070E2
2012/12/16 00:14:16 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:16 [Plugwise] Data wrong: 0000234900C1AD45
▒00132349000D6F00004B9B700001000400000139000000000006CF46
0000234A00C1B2EE
▒0013234A000D6F00004B9B70000000030000013900000000000A866C
0000234B00C15C3C
▒0013234B000D6F00004B9B70000000030000013900000000000AEA28
2012/12/16 00:14:16 [Plugwise] Data correct: 0000234900C1AD45
0000234A00C1B2EE
0000234B00C15C3C
0000234C00C1F66D
▒0013234C000D6F00004B9B70000000030000013900000000000A3E0B
2012/12/16 00:14:16 [Plugwise] GetPowerInfo Result: 00132349000D6F00004B9B700001000400000139000000000006CF46
2012/12/16 00:14:16 [Plugwise] Sequence Number: 2349
2012/12/16 00:14:16 [Plugwise] Pulses: 0001 (hex) 1
2012/12/16 00:14:16 [Plugwise] Corrected Pulses: 1.059625315676
2012/12/16 00:14:16 [Plugwise] kWh: 0.002259625243
2012/12/16 00:14:16 [Plugwise] Watt: 2.259625243109
2012/12/16 00:14:16 [Plugwise] Checking relay state of device 'Four' with address 000D6F00004B9B70
2012/12/16 00:14:16 [Plugwise] MAC: 000D6F00004B9B70
2012/12/16 00:14:16 [Plugwise] String: 0023000D6F00004B9B70 CRC: 6072
2012/12/16 00:14:16 [Plugwise] Write: 0023000D6F00004B9B706072
2012/12/16 00:14:17 [Plugwise] Write: 0023000D6F00004B9B706072
2012/12/16 00:14:17 [Plugwise] Needed to interrogate the stick more then once!
2012/12/16 00:14:17 [Plugwise] Data wrong: 0000234D00C191B9
000D6F00004B9B70
▒0024234D000D6F00004B9B700C0C542F000478A001856539090088044E0844C2024A2C
0000234E00C13BE8
000D6F00004B9B70
▒0024234E000D6F00004B9B700C0C542F000478A001856539090088044E0844C202EF72
0000234F00C1D53A
000D6F00004B9B70
▒0024234F000D6F00004B9B700C0C542F000478A001856539090088044E0844C20210B1
2012/12/16 00:14:17 [Plugwise] Data correct: 0000234D00C191B9
000D6F00004B9B70
0000234E00C13BE8
000D6F00004B9B70
0000234F00C1D53A
000D6F00004B9B70
0000235000C14099
000D6F00004B9B70
▒00242350000D6F00004B9B700C0C542F000478A001856539090088044E0844C202AB4D
2012/12/16 00:14:17 [Plugwise] GetDeviceInfo Result: 234D000D6F00004B9B700C0C542F000478A001856539090088044E0844C2
2012/12/16 00:14:17 [Plugwise] MAC Address: 000D6F00004B9B70
2012/12/16 00:14:17 [Plugwise] Sequence Number: 234D
2012/12/16 00:14:17 [Plugwise] Log Address: 453 (000478A0)
2012/12/16 00:14:17 [Plugwise] Time in Circle: 3084 12 21551
2012/12/16 00:14:17 [Plugwise] Frequency: 50Hz
2012/12/16 00:14:17 [Plugwise] Hardware version: 6539-0900-8804
2012/12/16 00:14:17 [Plugwise] Firmware: 2011/06/27 08:52:18
2012/12/16 00:14:17 [Plugwise] RelayState: 01 On
Sol-R
Re: Very long polling with Plugwise devices
Postby Michiel » Tue Feb 05, 2013 5:18 pm
Check this support issue: http://www.domotiga.nl/issues/217
It looks like (almost) the same error messages.
The new Plugwise code works good for me when I had the same errors as you.
Michiel
Return to DomotiGa Forum
