No open-zwave option under ZWave settings
Moderator: RDNZL
birdhouse99
Post by birdhouse99 »
Domotiga on Rpi.. Followed http://domotiga.nl/projects/domotiga/wiki/Z-Wave .
Installed with no errors but can not enable open z wave.
Any idea what could be wrong ?
U
wwolkers
Re: No open-zwave option under ZWave settings
Post by wwolkers »
What's the problem exactly?
There's a check box on the top right corner, which needs to be checked to enable Z-Wave support. Is that not working? Cause it's turned off at the moment.
j.hoekstra
Post by j.hoekstra »
Did you install the wrapper? Then you should be able to enable it in the settings. The only supported version now is the open z-wave version, so no need to explicitly enable open z-wave.
wwolkers
Post by wwolkers »
You DO need to enable it, or nothing will happen, wrapper or not.
What's in your logfile? If the wrapper is outdated, it won't stay enabled and give you an error in the log.
Return to “DomotiGa Forum”
