fibaro FGD-211 problem
Moderator: RDNZL
Postby arjveld » Sat Jul 27, 2013 11:41 am
Hello all,
Been looking here for a long time and just started out with my own project.
I've just stumbeld uppon a problem i just can't seem to figure out.
Tried my dimmer with incontrolHA and everything worked as expected, but i want to use domotiga as my main system.
so installed domotiga, zwave wrapper etc. The stick (Aeon Labs Z-Stick S2) is found, and the added dimmer (FGD-211) is also present in Z-Wave Commander.
Can turn lights on and sometimes off with domotiga.
when i look at the logs, under debug it seems that the stick contineus send a command for a second of 10.
2013-07-27 12:37:02 [Z-Wave] Got value changed notification for node 2 and instance 1 value1 changed to Off.
In the time that that happens i can turn the light off if that isn't running, the lights won't respond to anything.
furthermore the wall switch also stopped working since i added the stick to domotiga :cry:
anybody some info on what could be the problem?
Thanks in advance!
arjveld
Re: fibaro FGD-211 problem
Postby uAlex73 » Mon Jul 29, 2013 8:12 am
According to the part of the logging, the open-zwave is sending continuesly notifcations to DomotiGa (this is most likely the reason why it isn't responding anymore).
I am suspecting it is a bug/issue in the open-zwave library, can you email me your complete OZW_Log.txt and domozwave*txt logfiles? Then i will have look into it and if it is a wrapper problem, i will fix it for you. My email is uAlex73 [at] gmail.com
uAlex73
Postby arjveld » Mon Aug 05, 2013 8:03 am
Sorry for the late reply.
Thanks that you're willing to look in to this.
Tried sending the files, but they are to large for sending (44 and 26 MB).
I can cut them up if you want or just send the piece that you need the most.
logs are pretty large for that there is only one device in zwave...
arjveld
Return to DomotiGa Forum
