Can't switch Popp/Duwi ZDAN 300 dimmer
Moderator: RDNZL
pservais
Post by pservais »
Finally bought a Aeon Labs Z-stick 2 and a Popp/Duwi ZDAN 300 Dimmer, time to test :)
Dimming works fine but I can't switch it on/off, neither can I dim 0 or 100.
I've tried it with the Zwave Commander, control devices and a action.
Neither of the tests gave result.
All the sw is up to date (DomotiGa and open zwave)
Does anyone can help me? I would really like to switch from KaKu to Z-Wave.
uAlex73
Re: Can't switch Popp/Duwi ZDAN 300 dimmer
Post by uAlex73 »
Can you supply me your debug Z-Wave logging, OZW_Log.txt and zwcfg*xml while you preform a Dim action, On and Off. Then i should be able to pinpoint the problem and fix it.
The Dim 0 is automatically translated to "Off" and Dim 100 is translated to "On". So if On/Off doesn't work, neither of those 2 will work.
pservais
Post by pservais »
sorry for the late reply. We were on vacation until this evening.
Can I email you the logs? Somehow the forum doesn't let me attach the logs to this reply.
Thanks in advance!
uAlex73
Post by uAlex73 »
np ... just send them to uAlex73 [at] gmail [dot] com
pservais
Post by pservais »
They're on their way.
uAlex73
Post by uAlex73 »
@pservias:
I looked into the logfiles, if you use the LATEST wrapper, it should work. Can you confirm you compiled the latest one?
Return to “DomotiGa Forum”
