No devices in web interface
Moderator: RDNZL
mschut
Post by mschut »
On to the next issue....
I am not sure what caused it, but in the web interface of DomotiGa (on Raspberry Pi) I don't see any devices anymore. I did use to see them, but they are gone.
I did upgrade to the latest version, and changed from gambas2 to gambas 3, although due to some problems acheiving this, I am not sure the upgrade by itself / the gambas upgrade could be the problem. However, trying to reinstall according to the manual on http://www.domotiga.nl didn't bring the devices back.
Anyone recognise this as a "simple" issue (and hopefully with a simply solution)?
Synology DS213+ / Domoticz / RFX Transceiver-e
uAlex73
Re: No devices in web interface
Post by uAlex73 »
Can you try the following command:
$ xmlrpc 127.0.0.1:9009 device.list
It is should respond with something like:
Result:
Struct of 25 members:
  Key:   String: 'Porch Light'
  Value: String: '1;;light-on.png;;Porch Light;;Frontdoor;;On;;;;;;;;;;;;;;;;2008-12-14 18:00:00;;;;T;;'
  Key:   String: 'Power Usage'
  Value: String: '2;;energy.png;;Power Usage;;MeterCabinet;;4497256;;;;0;;Watt;;;;;;;;;;2008-12-14 21:53:01;;;;;;'
mschut
Post by mschut »
Note: I've been away from this forum awhile because my uptime of my raspberry was very poor.. I changed the device, and hopefully now it will stay on again.
Anyway, I've tried the suggestion, it says:
-bash: xmlrpc: command not found
That's not very helpful is it...
RDNZL
Post by RDNZL »
You have to install it first.
On my Ubuntu distro it's in libxmlrpc-core-c3-dev
$ sudo apt-get install libxmlrpc-core-c3-dev
Regards, Ron.
mschut
Post by mschut »
I have reinstalled everything on the page Web & Mobile Clients - Domotiga but stil... NO devices at all. The webpage http://www.mydomain.com/domotiga is working, the iphone client http://www.mydomain.com/iphone is working. The only issue missing are the devices.
Oh please, it took me another evening without any result. Has anybody an idea? Since I followed everything on the page mentioned, I have the feeling the required xmlrpc should be there. It did mention some xmlrpx with the php5 files, but as I said, no change to the good has been achieved....
Situation:
Raspberry PI B
DomotiGa 1.0.009.
uAlex73
Post by uAlex73 »
@mschut:
There can also be something "weird" in the xml response, can you make a tcpdump of the xml-rpc traffic and email it to me?
to make a tcpdump:
sudo tcpdump -i any -s 0 -w /var/tmp/xml.eth port 9009
mschut
Post by mschut »
Thanks for the reply, I quickly tried, but again:
Sudo: tcpdump: command not found
Something is missing I suppose.....
uAlex73
Post by uAlex73 »
You can install tcpdump as follows:
$ sudo apt-get install tcpdump
mschut
Post by mschut »
Installed, check.
Performed command, check.
Mailed the file, check.
For me, It doesn't make any sense what's in the file :shock:
mschut
Post by mschut »
Found the error, thanks to uAlex73!
"Do not use an "&" in the names of the devices/locations".
Now I know...
Return to “DomotiGa Forum”
