Domotiga Ethernet Z-Wave support
Moderator: RDNZL
Postby raymonvdm » Fri Nov 29, 2013 8:15 pm
I did not find the answer yet but will DomotiGa support ethernet based Z-Wave adapters (or ser2net interfaces?)
Ser2Net setup which is working in Homeseer
viewtopic.php?f=7&t=9148
raymonvdm
Re: Domotiga Ethernet Z-Wave support
Postby RDNZL » Sat Nov 30, 2013 4:59 pm
Currently the OpenZwave code of DomotiGa only supports serial ports, but if you can emulate one you can try to see if it works ok.
I don't know anyone using it yet.
The RaZberry Zwave code in DomotiGa already supports IP based communication, so using a RasberryPi or Cubieboard with RaZberry module as IP controller works.
Regards, Ron.
RDNZL
Return to DomotiGa Forum
cron
