Tutorials on how to create a gui using CommandFusion iViewer
Moderator: RDNZL
Re: Tutorials on how to create a gui using CommandFusion iViewer
Postby thechad » Thu Feb 20, 2014 2:01 am
Hi, whizzkey,
Thanks for the post.
I suspect you are using an old version of DomotiGa :)
The code was changed a while ago to send a 1 or a 0 for on and off for "switch" and "dimmable" devices.
There have also been a number of other improvements.
With the move to github, the upgrade process has changed (but is still just as easy!).
You can get the iunstructions here. http://www.domotiga.nl/projects/domotig ... Ga_Upgrade
All that said, I am glad you got it working in your version as Regex is black magic to my mind!
Fortunately guiDesigner has a regex tester inbuilt...I also use this site http://regexpal.com for testing.
Oh, and there should be some exciting changes on the way too. We are in the final stages of moving interface over to jsonrpc over "raw" tcp, which will do away with the need for the iViewer interface altogether and make it even easier to interface DomotiGa and iViewer.
thechad
Postby Mediacj » Thu Feb 20, 2014 8:17 pm
thechad wrote:Hi, whizzkey,
Wow that would be great!
I already purchased the Iviewer lite version so now I can use more then one page :D
I am still in the stage of connecting my devices to Domotiga and Iviewer but it is fun to learn so much on the different disciplines you can use to make it al work.
Mediacj
Postby Mediacj » Sun Mar 02, 2014 10:12 pm
Hi Thechad any News on the jsonrpc interface for iViewer?
Mediacj
Postby thechad » Mon Mar 03, 2014 12:24 am
Hi mediacj,
As I understand it, it's partly there in the latest release...but still very Beta and undocumented. So you can connect now and send jsonrpc commands to DomotiGa over raw tcp.
Importantly though, the real time status updates back to iViewer are yet to be coded.
I am doing the iViewer side (not the domotiga code) and the guys are very buys (just look at all the changes in the latest release) so we'll just need to be patient :)
Also, I have very limited time at the moment, so there may also be some delays on the iViewer side.
cheers.
thechad
Previous
Return to DomotiGa Forum
cron
