Automatic reboot when inserting Aeon Labs Z stick
Moderator: RDNZL
Postby tonynelson » Thu Mar 20, 2014 1:27 pm
Any time that I insert the Aeon Labs Z Stick v2 into the Raspberry Pi it causes the Pi to reboot.
Have others experienced this? Is it standard behaviour? It's not something I'd normally do a lot of but it happens a lot while I'm trying to add new nodes to the system.
Thanks for any feedback.
Tony.
tonynelson
Re: Automatic reboot when inserting Aeon Labs Z stick
Postby wwolkers » Fri Mar 21, 2014 2:51 pm
Must be power related.
The Aeon stick should not be used directly in the PI, but via a powered hub.
wwolkers
Postby raymonvdm » Sat Mar 22, 2014 10:35 pm
I also had this issue when plugin in directly to the PI so i used a Dlink powered hub which has a 5V 3A power supply so it should give you enough power for the PI and the Aeon Labs
http://www.bol.com/nl/p/d-link-7-port-h ... 005771908/
raymonvdm
Return to DomotiGa Forum
