Signal lost
Moderator: RDNZL
Signal lost
Postby Pik » Sun Apr 13, 2014 3:38 pm
I use ~30 devices and I found sometimes DOMOTIGA don't receive a signal or don't make action.
In fact, it seems that when DOMOTIGA is sending a signal in same time an other one is received, TX Signal is not received by RX device 1 and TX device 2 (eg:PIR) is not seen by DOMOTIGA.
Q1 : should it be possible to avoid this trouble (to queue TX until RX finished)?
if not possible, the other way is to identify if nobody at home (or no movement since a period) and in this case, to switch all lights I wish.
Q2 : As I just arrived in DOMOTIGA 2 days ago - so, no experience, could you explain how to write an event or macro in order to read if no motion on all PIR since 10 minutes (example), to switch off all lights.
If we consider for the example PIR_1 & PIR_2 with 2 lights (Light_1 & Light_2)... what could be the macro ?
I tried to find a way using lastseen, but I don't understand how to use it ... maybe not the good way...
() My knowledge is today only how to create a device, an event with trigger, action and condition... quite simple... and this function seems to be more complicated... I need to learn !
Thanks a lot for your appreciated support.
Best regards.
Pik
Re: Signal lost
Postby uAlex73 » Mon Apr 14, 2014 7:15 am
Are you using a RFXComTRX or another device for sending/receiving?
uAlex73
Re: Signal lost
Postby Pik » Mon Apr 14, 2014 11:59 am
Thanks for your feedback.
No, I just use one RFXCom.
For example, I have a corridor with one sensor (PIR#1) and one light (#L1) with upstairs and one sensor bottom (PIR#2), one sensor top (PIR#3) and one light (L2) fro all upstairs.
When I arrive in this corridor, if I walk quite fast, I activate PIR#1, DOMOTIGA is sending signal to L1 but in same time, I activated PIR#2 but as DOMOTIGA was sending a signal, it seems it didn't seen the PIR#2... When I arrive on Top, L2 is shining.
Sometimes, I can see some other lamps "On" but in Domotiga, status is Off. If I switch ON/Off, I recover the good status.
Device is near RFXCom, so not a range trouble.
So, the idea is to have an event/script switching "Off" all lights after a period of time (for example 10 minutes) if no movement inside home (no PIR signal since 10 minutes).
I wrote a short script comparing device_x_lastseen and now()... when I run it, I can see good result (true or false), but I don't know how to use this script (macro) and how to switch off lights.
Thanks for your help.
Pik
Re: Signal lost
Postby b_weijenberg » Mon Apr 14, 2014 2:01 pm
Is the RFXCOM an RFXtrx433 transceiver or an RFXCOM receiver and an RFXCOM RFXmitter?
If it is an RFXCOM receiver and an RFXCOM RFXmitter: did you connect the handshake cable between the receiver and transmitter and is the transmitter configured to use the handshake?
b_weijenberg
Re: Signal lost
Postby Pik » Mon Apr 14, 2014 7:40 pm
it's a RFXtrx433 USB 433.92MHz Transceiver (model 12103 on RFXcom web site)
The trouble (RX/TX signal) is not critical for me if I can send a signal later to force all lights Off.
Do you know how to create such event able to switch off all lights if no movement since xx minutes ?
Pik
Re: Signal lost
Postby RDNZL » Mon Apr 14, 2014 8:58 pm
Since there is already a queue and tx busy check in the code I can simply add a rx busy check using 3 lines of code.. Will try tomorrow...
Regards, Ron.
RDNZL
Re: Signal lost
Postby Pik » Tue Apr 15, 2014 11:33 am
OK... I think this can solve this trouble.
Awaiting your feedback. (please, could you also explain later how to update my DOMOTIGA with this new code ?).
Best regards.
Pik
Re: Signal lost
Postby raymonvdm » Wed Apr 16, 2014 2:38 pm
Pik wrote:OK... I think this can solve this trouble.
Best regards.
In the past i used
cd /home/domotiga/
svn up
raymonvdm
Re: Signal lost
Postby Pik » Thu Apr 17, 2014 5:36 am
cd /home/domotiga/
svn up
I have path missed !
I'll check this evening if I can find procedure to update... I have to leave home now...
Pik
Re: Signal lost
Postby Pik » Thu Apr 17, 2014 12:01 pm
OK... I made an update using this procedure :
$ mkdir -p  ~/install
$ cd ~/install
$ git clone https://github.com/DomotiGa/DomotiGa.git domotiga
$ cp -rp ~/install/domotiga ~
$ cd ~/domotiga
$ rm -rf `find . -type d -name .git`
I hope it's the good way as svn up was giving message path missed.
... but where to see if udpate is implemented or not ?
Do you know if any update traçability ? I still have 1.0.015
If update implemented... I'll see if improvement. I keep in touch with you.
Pik
Re: Signal lost
Postby j.hoekstra » Thu Apr 17, 2014 1:03 pm
Pik wrote:cd /home/domotiga/
svn up
Check the site, switched to git.
In essence you need to completely checkout via git, well described and if you follow the steps, no data is lost.
Sent from my Nexus 7 using Tapatalk
j.hoekstra
Re: Signal lost
Postby Pik » Tue Apr 22, 2014 8:58 pm
OK. Update done and also a script to check if no movement since a delay and if TRUE, to force switch Off devices.
DOMOTIGA is really so great !
Thanks for your support.
Pik
Return to DomotiGa Forum
