I see a lot of plugwise errors in my HS2 log, i didn't change anything in the settings or files.
What is wrong here?
31-10-2014 23:37:12 Error Web Server Error 404, cannot serve file: C:\Program Files (x86)\HomeSeer HS2\html/images/Plugwise/Icons
31-10-2014 23:37:19 Plugwise ERROR: Appliance.Update: Exception: Object variable or With block variable not set., at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ctor(Object Instance) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at HSPI_PLUGWISE.Appliance.Update(Appliance& oAppliance)
Errors
Re: Errors
I have also a problem with my Smile P1, each time when I add the smile the configuration in HS2 is lost, this hapens after one or two days.
I can get it back by configuring the smile P1 again in the source software.
Re: Errors
why not: remove it from the source and add it to hs2 (plugwise plugin)
Re: Errors
Thanks I shall try it, but what do I use in the following fields;
Smile P1 user ID
Smile P1 password
Greetz
Smile P1 user ID
Smile P1 password
Greetz
Re: Errors
Sorry, found it yet in the manual of version 2.2labtec wrote:Thanks I shall try it, but what do I use in the following fields;
Smile P1 user ID
Smile P1 password
Greetz
After fill in the user ID and password I get the following error:
Plugwise ERROR: PollSmileP1: Cannot query http://192.168.1.153/core/modules: The remote server returned an error: (404) Not Found.
Re: Errors
my version reads: not used yet (password etc)
