Plugwise stretch help needed
Postby Geertjen » Mon Mar 23, 2015 11:24 pm
I bought a stretch 2.0 via markplaats. This came without a circle+.
I also have a source set. Is it possible to link the circle + of th source set to stretch 2.0?
Is it correct this can be done by opening the stretch 2.0 box en replace the zigbee usb with the source stick?
What steps needs to be done?
Re: Plugwise stretch help needed
Postby RdP » Wed Mar 25, 2015 12:54 pm
Please contact Plugwise, they can/will help you set up with what you need.
Postby PietjeNL » Wed Mar 25, 2015 2:51 pm
Easiest way is to open the Stretch box and put your source stick into it.
:!: Be warned this is not officially supported :!:
Open stretch en remove stick.
Boot stretch and after boot hold 15 seconds the reset button, u will see it turning red around 15 seconds and then release it.
Wait for it to boot again and disconnect the power.
Now put your own stick from source in the stretch and let it boot and do its thing for 15 minutes.
Now u should have all of your modules visible in the stretch.
Return to Plugwise Forum
