Transfer historical data between plugs
Postby Darwusch » Fri Dec 11, 2015 9:55 pm
I would like to transfer the historical data from one plug to an other in the database.
Not in the buffer from the plug itself, but I mean the data in the database (Source).
Who knows how to do this?
The reason is because I used a plug for my solar panels, and now I changed the plug to a stealth.
But I want to keep the historical data and add it to the history of the new stealth, so the solar data stays together.
Darwusch
Re: Transfer historical data between plugs
Postby PietjeNL » Thu Dec 17, 2015 1:30 pm
In Source u can find the appliance button under settings.
Under there u'll find on the left the appliances, this is also the log data.
Notw drag the solar panels appliance to the meters part, on the top left side.
The appliance still exists with all the data but there is no meter connected to it (u should see the disconnected meter on the meters part)
Now u can add the stealth module to the network and when done so u will see also the stealth in the meters part.
Drag and drop the stealth on the solar panels and the stealth should continue to log on the appliance.
PietjeNL
Postby Darwusch » Sat Dec 19, 2015 11:59 am
Thanks, that did it :)
Darwusch
Return to Plugwise Forum
