Weird behavior Stretch after switch from source
Posted: Tue Apr 26, 2016 3:41 pm
I recently got a second stretch+stealth from the internet, the migration path from source is not very customer friendly sending things etc. So I had two choices or redo the whole network again with stealth+ or to follow the none supported migration by resetting the stretch and insert the source dongle.
So I went for this last option. After doing the reset and reboots I inserted the stick to soon see all the plugwise modules appear and turn green on the stretch web page. So far so so. Now after a little while they all lost connection and turned grey. However on the xml data files (using this to load to a hc2) I did see all the modules, status and use. Also when using the app I get the information they are up power usage able to turn on/off etc. So basically all works except for the stretch page that does not seem to update or allow access to the modules. I did notice that only on the stretch page I still see the stealth+ listed. This is not so in the app.
The question is did anyone try this before and what kind of result did you get?
Any idea why this isn't working and how to fix?
Thx
Thx
