HomeSeer HS3 Plugwise Pro 3.5.0.0 beta!
stefxx
Post by stefxx »
I believe it is time for a first beta. Please note that internally almost everything has changed, and also on the outside the changes are very noticeable. So take your time if you consider helping me with testing. Here is a list of a few of the changes:
- The plugin is no longer free. Beta versions will be valid and free for 1 month. But be prepared to upgrade sooner or later to the paid version because all settings, devices, events etc will be changed in the upgrade process.
- Support for multiple plugin instances is removed. Instead an unlimited number of gateways are supported inside the same plugin instance. This saves processing power, memory and is is also more intuitive.
- Stick setup is greatly improved. Communication with the stick is enhanced and much faster. Detection of devices, especially battery powered devices, is not only better but also guided to avoid issues.
- Manual adding of devices is removed (because of better device detection and internal changes)
- Devices are more "Z-Wave" style with a root device and all device values are now stored in separate child devices.
- Online/Offline status (Stick only) is moved to the root device
- Stealth modules are now working as expected with the Stretch
- The setup of the Stick, Stretch, Adam, Anna and SmileP1 is much more intuitive and contain an indication of the accompanying process is running.
- Logging is greatly improved. It is now possible to log to file for every device in a separate file. This will make troubleshooting much easier (also for me :))
- Script functions have been removed. Since there are separate devices for all devices values, they are no longer necessary.
- The same for the Plugwise specific events, they are no longer required also. For both script and events there will be a check during upgrade to warn for existing scripts and events still using the old functions. Manual changes will be required to fix this issues.
- The Stretch now supports the Switch, Scan and Sense (note: if you use the Switch and Scan, the experience will be a lot better if they are connected to the Stick. Due to the way the plugin communicates with the Stretch, Scan and Switch actions might be very slow)
- The Stretch 3.0 is now also supported.
- The Anna is supported, still experimental
- The Adam is also supported, even more experimental
- The Lisa has been tested with the Adam. Koen, Tom, Floor and Plug have not been tested and will most likely not work or cause issues. If you use those devices, please reach out to me so you can help me get them properly supported!
- The "Total usage" device will be removed. If total usage is required, please use a SmileP1 to really see your total usage. Or create a simple script to get the totals required. If this is really an issue for some of you, I can assist in creating a script.
PLEASE: ALWAYS MAKE A FULL BACKUP FIRST!
Last but not least; testing under Linux hasn't started yet. Feel free to try, but be prepared for the worst.
Unzip the file, and place HSPI_Plugwise_Pro.exe in the root of your HomeSeer folder. Also, unzip the images.zip file and place the content in <HomeSeer>\html\images\Plugwise Pro (usually "C:\Program Files (x86)\HomeSeer HS3\html\images\Plugwise Pro").
Good luck! Let me know how your upgrade experience was, and what you like or dislike about the new plugin. If you run into issues, please report them so I can fix them!
Update 2019/06/01: Beta 2 with the following changes:
- Fix: Some logging was accidentally suppressed
- Add: Toggle support for Adam and Anna devices (for instance Comfort mode and Proximity Sensor)
- Fix: Linux only: Thermometer icons were missing
- Fix: Linux only: xml error while reading "Watt" and "kW Hours" values from Stretch 2.0
- Fix: Linux only: several Mono compatibility issues
- Add: Option to use all four Switch buttons independently with timeout
- Add: Configurable Scan timeout
- Fix: Several little fixes and stability improvements
Update 2019/06/04: Beta 3 with the following changes:
- Add: Device address discovery based on ID
- Add: Anna and Adam buttons configurable timeout
- Add: Anna and Adam Offset implemented
- Fix: Linux only: Adam ReadDone1 error
- Fix: Linux only: Preset now working correctly
- Fix: Even more little fixes and stability improvements
- XML reading performance improvement
Download here: https://download.dedroog.com/HSPI_Plugwise_Pro-3.5.0.3-Beta3.zip
Edwin2008
Re: HomeSeer HS3 Plugwise Pro 3.5.0.0 beta!
Post by Edwin2008 »
Damn, you're fast. Still need to find time to install new windows box with HS3 :(
** edwin **
stefxx
Post by stefxx »
A few screenshots:
Setup with unlimited gateway support
Stick device detection
Stick setup.PNG (68.39 KiB) Viewed 11279 times
Stick devices
Stick devices
Anna devices
Anna devices
Adam with Lisa
Adam with Lisa
Edwin2008
Post by Edwin2008 »
Looking good. Can't wait to participate but have different priorities at the moment. Will join asap.
** edwin **
Akatar
Post by Akatar »
It's running and working!
I had to create the plugwise pro folder for the images, because it wasn't there. no sweat
so, the opentherm gateway can in the "kliko" :)
stefxx
Post by stefxx »
Great!
The images/Plugwise Pro folder will be created by the official installer. That will be included in the official release through the HS3 updater.
Thanks for testing (and allowing me to access some of your devices!). Let me know if anything strange happens.
stefxx
Post by stefxx »
Beta 2 available, link updated in first post:
stefxx
Post by stefxx »
Beta 3 available, link updated in first post. This might be the last beta before I release the plugin to the HS3 updater.
Mainly fixes, but also added some nice features like device discovery based on the ID of the device.
Akatar
Post by Akatar »
stefxx wrote:Beta 3 available, link updated in first post. This might be the last beta before I release the plugin to the HS3 updater.
Top, dan zijn we ook van de "timebomb" af :)
stefxx
Post by stefxx »
Just make sure not to find any bugs then :)
Akatar
Post by Akatar »
stefxx wrote:Just make sure not to find any bugs then :)
if i find any, you'll be te first to know :)
Bastiaan
Post by Bastiaan »
Finally time to install and setup. I have only circles (about 20) but all Seems ok. Seems we can finally use a “clean” power use value in events :-)
No plan to make the virtual Total device again.?
Bastiaan
stefxx
Post by stefxx »
Bastiaan wrote:No plan to make the virtual Total device again.?
No. I always hated that option. The only reason it existed was because the Source program had a similar feature. But it was always inconsistent (for instance, the Stretch did
not support this) and I never understood why anyone wanted this half baked feature anyway. If you want whole house usage, try a P1 meter (Smile P1 or just a USB P1 interface), and if you want to have totals from all HomeSeer devices, do it right and don't limit it to the Plugwise circles connected to the Stick.
So, for anyone who insists on have a Grand Total device again, see here: https://forums.homeseer.com/forum/3rd-p ... ost1309452.
stefxx
Post by stefxx »
Plugwise Pro 4 is released! viewtopic.php?f=39&t=12456
Phaeton
Post by Phaeton »
Hi, I cannot find the plugin in the updater. Currently using the old Plugwise Pro and I am willing to pay/upgrade but cannot find it in the updater. Is this also an issue on your side Stef?
groeten,
Return to “Plugwise Forum”
