Plugwise Source home edition v1.0 key
I'm about to install the Plugwise Source home edition software on a test server, but the software (to activate and install) needs an internet connection.
Problem (1). The test server does not have an internet connection. So I can not activate (and install) the software.
Problem (2)? if I install the software on a test server that does have an internet connection, will I be able to install it again (and activate) on an other "production" server when done testing?
The software will be removed from the 'test' server.
Anyone here who can confirm that reinstalling and activating (again) the software on an other PC is no problem!?
1 - About activation I'm not 100% sure..
I think you need the connection.
2- Plugwise has build in backup DB option. Backup the test server.
Install the software on the new server..
Stop the installation process when it's asking for activation.
from start menu run restore plugwise Db..
start the new server...all will work fine with the settings from your test server.
you need Internet to activate, otherwise no go!
- Snelvuur
internet to activate, thats pretty stupid.. if i just want to use my laptop, and install it somewhere to check out some data.. o well...
After activation there is no need for Internet connection.
- Snelvuur
but you have to copy the database over, otherwise it wont work you say ;p
Can i install the Source a second time on another system and start all over again? For example when the first system crashes and you don't have a backup? What's the 'wisdom' behind using activation anyway?
You can do that..activation is for the software connection to you name.
Ok, that's fine, so no use counter on the other side cause that would be silly.
I'm sure they have more...like the USB device serial number that is connected to your key.
What do you think Chak, is only the serial number of the USB device send to Plugwise? Or also information about the number of plugs you use and how you use them?
I think they can see more.
also the serial numbers of the devices
That's against the privacy law, and if they also can collect other useful information "Power usage". Nice items to sale to the power company. i don't like that at all.
gr Ruud
gr Ruud
Ruud you're right, when it comes to privacy, <b>i</b> want to be the one in control of what information is sent to whatever. I don't mind my name sent in registration process, but nothing more. And i sure don't like <b>guessing</b> what more is sent!
Can't you uncheck "Allow data/statistics to be send to Plugwise" during installation of the software? I had this option during the installation of release 20081110.
Now or in the future you'll be able to login to my.plugwise.com to check your power usage.
DJ
DJ
