Plugwise Stretch Lite
<to start a topic for this product>
I just saw the Plugwise Stretch Lite available at this webshop:
http://www.radiowinkel.com/?menu=articl ... ID=5705335
The weird thing is that there's no mention of this product on the plugwise.nl website. Is it from Plugwise itself? Has anyone seen documentation or tested the product?
Thanks
DJ
Thanks
DJ
It just a USB to Ethernet controller, I think it has the same functionality as the Belkin USB2Ethernet.
The Belkin has more ports for other usb devices.
The product is from Plugwise though.
- Snelvuur
Would have been nicer if it had like a small o.s. on it with a tiny webserver.. then it would also solve the "linux" support issue.
That is a device they are planning to release next year.
This might be a alternative if i can't get the USB working with the Belkin USB LAN thing.
Same for me, want it right away.
- Snelvuur
@bwired: well put that device on the wish list for plugwise "issues"
Price will be the problem for must of us..it will be same as the HCB..> 700 euro
maybe Eaton is going to buy them and it will be part of Xanura line...including HCB support...
<br />@bwired: well put that device on the wish list for plugwise "issues"
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">You did not look very good, its way on top
<b><font size="6">PRIO 1</font id="size6"></b>
<br />Price will be the problem for must of us..it will be same as the HCB..> 700 euro
Not for the version with build in application server...or did i mis something.
The link in the 1st post doesn't say anything about built in application server..?
<br />Would have been nicer if it had like a small o.s. on it with a tiny webserver.. then it would also solve the "linux" support issue.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">yep..reply was about this one..sorry..
I know they are working on a version with build in OS and application including webserver.
Chak. Make sure that you use the quote option correct
The picture is different on the plugwise website (http://www2.myplugwise.com/producten/pr ... twikkeling) and it also mention that it is needed if you have more than 65 plugs.
