Ruud,
First: I'm pretty sure they won't. There's not a large market for these plugs and it won't give them $M's of revenue.
Why would you want to use a Circle on your ventilation system?
Most of the ventilation units that use a perilex plug have a switch in the kitchen which has 3 options:
1- ventilation=on
2- ventilation=faster
3- ventilation=fastest
Result: you may never turn it OFF. A Circle with perilex would turn it OFF.
What I did to switch the mechanical ventilation can be found on my website, under 'How?', section "ventilation"
http://www.domoticaworld.com
So if you want to use it to monitor electricity usage you could do this:
-Use an RFXCOM RFXMeter and RFXPower
-Use the ventilation systems specs to find out the power usage. Use this as a 'fact'.
I don't think you can use a Circle to measure the power usage on a ventilation system with Perilex plug as these have 3 Live wires (hence the 5-pin perilex plug).
Hope this helps a bit..
Cheers
DJ
Plugwise circle for perilex
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
