I like the concept of Plugwise, but I'm not really sure if it's the right choice yet. First of all I'm a Homeseer user and the interfacing between HS en Plugwise is a little tricky (no 'real' plugin) And on the other hand, i do have a lot of (even a number of unused) marmitek plugin lamp and appliance modules which I don't need anymore after I ordered the plugwise set.
Is it an idea if I ordered the home starter kit to see if it fit my needs and then decide to order an extension kit later.
Does this work with only 2 circles, I heard the Zibee network must be as large a possible to get the best results....
Best regards,
Some advise
Some advise
Yes it works otherwise Plugwise would not sell this
You can test for yourself in which case the network with a few circles is still stable.
If it's not stable you have to move the circles closer or to other places.
But it can work, however if you have a few more circles your house is covered more easily.
