Okay.
When I have my plasma TV on AND my laptop connected to the power supply some of the Xanura units rear the units have problems (sometime they do not respond)
When only the plasma is on, OR the laptop (connected to power suply) I do not have this problem.
The plasma allready had a plug, but as test I also added a plug to the laptops power supply.
Guess what... No more problems at all with any of the Xanura units when both the plasma en laptop / power suply are on
I guess that the plug's do have somekind of filter in it.
Plug = good (xanura) filter for trouble units :-)
- Snelvuur
nice to know, so if you measure all your equipment anyway, you have filters for it then right away?
That would be cool! That will save alot in costs.
I also notice that..the filter is very weak..if there is lot noise you will still need a real filter.
same problem (still), plasma on problems on some modules, plasma off no problems. Stuff is equipped with a original Xanura filter but no luck. Will discuss this issue at a xanura course in jan'09
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=1817
If it walks like a duck, quacks like a duck, ....
