Keeping the Stealth next to a circle I doubt that they use the same print, the Stealth print seems to be bigger. I'm not gonna open one up just for kicks.
I'm using a stealth in my Bathroom now, built in a watertight box to power my washingmachine, it switches on in the morning before the low tarif ends to do the laundry.
Stealth product sheet.
- Member
The first thing i did was to open one up to inspect. They look the same and are the same on the milimeter. Only differense is that it got a longer board to hold the "jacket" dont know the word.
So its kinda easy to modify a circle to be the same as a stealth. Just ordered another 10 circle that all will me modified.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by daromer</i>
<br />The first thing i did was to open one up to inspect. They look the same and are the same on the milimeter. Only differense is that it got a longer board to hold the "jacket" dont know the word.
Can you post a picture of that? How will you connect to the board when you're missing the jacks?
I just make some new brackets to hold the cables. will test to do one when i get the other ones.
http://luno.mine.nu/bild.jpg
Sorry for the lousy picture. took it with my cellphone.
But as you can see they are almost the same except for the shape of the mainboard.
I will put up more when i looked over them more.
Edit: But i must state that it aint legal to do this and install it afterwards. It is only approved as it is!.
- Starting Member
Wow. That's interesting! Do you have more pics?
I am using 1 stealth by the way, but cannot connect it to the source. Does someone else have these problems?
Chris
Chris
I use 1 stealth connected without problem. I first connect them in a virtualized environment then i use POL.py to read them.
Will get back with more pictures later on.
(I also work on a project like plugwise, though with some other functionalities.)
- Starting Member
- Starting Member
Re: Stealth product sheet.
I'm interested. But I want to know about the price first ofcourse ?
Yogi
Yogi
Resetting Stealth
I'm pondering about putting some Stealth' behind the fuses into my fuse box to get whole circuit consumption (kitchen, basement, garden, washing machine/dryer in the basement). Unfortunately, from what information is available, Stealth still seems to lack a reset button -- switching a whole circuit there times off-on to reset a Stealth doesn't sound comforting neither does having an electrician to do this by rewiring. Does anyone here know if "The Stealth’s functions and specifications are identical to those of the Circle" extend to it's resetting procedure?
-kai
-kai
Kai 'wusel' Siering, Blog: http://blogdoch.net/
