Plugwise stick not found
After a install of my IRTrans lan yesterday my plugwise is not working anymore.
The USB stick is not working and not recognise by windows anymore.
I have deinstalled the IRTRans software,startup again and try to install the stick but it doens't work anymore.
Somebody?
- Antoon
Somebody?
- Antoon
Strange!
Did you try to reinstall the source software, the irlan has nothing to do with plugwise.
Plugwise uses USB and not LAN. Perhaps something happend with the USB driver?
I have try everything and I don't understand.
I am sure it is happen after that I installed the IRTrans software because it is the same time that the plugwise is stopped.
When I installed it for the first time a couple of weeks ago, I had the same problem, but then the bluetooth driver was the problem.
I had to uninstalled that one first before installing the plugwise.
But when I connected the stick it was visible in windows,and now not anymore.
- Antoon
<h6>
- Antoon
<h6>
The same problem hire, after install de Irtrans with usb, all the usb devices ware lost.
After install the original Rfxcom driver, I cot the Rfxcom and plugwise online.
After de-install Irtrans and install Irtrans without the usb in the Irtrans setup, it works fine.
I know this problem from the past with USB Irtrans and first version of plugwise..
Just replace the FTDI drivers with the new one from there website.
Of you have the Lan version you don't need to install the USB version
I have no USB IRTrans but the LAN version so it doesn't make sense to me why the plugwise is stop working now.
At least my IRTrans is working now.
Service from IRTrans is really great I must say.
Now further to get my Plugwise back to work [:(]
- Antoon
<h6>
- Antoon
<h6>
Antoon,
In the main Irtrans software there are also USB drivers included.
Just roll back the FTDI driver in devices.
What was the problem with Irtrans?
Enver,I was in a wrong IP range with the IRTrans.
How do I rollback the FTDI driver, I don't see this in devices.
- Antoon
<h6>
- Antoon
<h6>
This is the correct working version of the FTDI driver
In the device manager just click on the plugwise com port
Enver, that is the problem.
There is no plugwise comport anymore.
- Antoon
<h6>
- Antoon
<h6>
rescan for new devices..
you can download the driver from ftdi website and reinstall..this will also solve the problem..(I hope)
http://www.ftdichip.com/Drivers/VCP.htm
Rescan doen't show anything.
I connected my second USB RFXReceiver and this things is also not in the device manager anymore.
The driver is not an install version so how can I install it for a device that is not visible?
This really sucks.
- Antoon
<h6>
This really sucks.
- Antoon
<h6>
Did you try a totally different USB port?
try deleting the USB Serial converter and than rescan..(Universial serial bus controllers/USB Serial converter)
if you don't see this
click view/show hidden devices
Pieter I have try all USB ports but it doesn't work.
- Antoon
<h6>
- Antoon
<h6>
