New release Plugwise Source 2.0.1 Final, Release 20091021
This is a minor update, prior to the release of version 2.1. It has no new functionality, only bug fixes.
It also does a one time clean up of the database, which can take some considerable time, the first time Source is started after the update.
Fixes:
- Sending schedules might fail
- Modules show status 'offline', when they are not
- USB icon stays in 'Busy' state
Changes
- The first time Source is started since the Daylight Saving Time has started or ended, the user is warned to resend the time schedules.
Please report any bugs to
helpdesk@plugwise.com
Include the version number of your Source application in your report. You can find it in the bottom right of the blue title bar.
Previous release:
Plugwise Source 2, Release 20090620
Changes:
- Format of export file.
Fixes:
- #264 In some cases Configuration Wizard does find Circle+
*editted post from beta to final.
Fixes:
Changes
Previous release:
Changes:
Fixes:
- Starting Member
Any idea what version 2.1 will bring us and when?
Rgards,
Arno
Rgards,
Arno
yes, seen already, but not yet a beta release available. Not on topic right now, maybe I can try to show some details in a different topic.
Can someone post the link to the file, my Source only gives `pdate errors` since day one. The version on http://www.myplugwise.com/ is also still at v20090620.10 )which is not mentioned anywhere on the site.'
Are you a registered beta user? If so, please try executing the update wizard directely from C:\Program Files\Plugwise\Plugwise Source\PlugwiseUpdate.exe
Thanks for the help. I am pretty sure I registerred with an email but don't remember getting a reply.....
running the updater directly:
It runs, checks internet than errors out with:
'an error occurred, retry? "
The error was: "the update check failed"
very funny but not very helpfull. [:D]
I installed the update and checked whether or not my Homeseer plugin is still working, and yes it is. So people who were waiting for me to verify (Enver ), I did not experience any problems (but I upgraded only a few minutes ago).
Rene,
Thanks for the update.
What is the one time clean up of the database exactly doing?
Great, just got an email from support with a direct download link.
Everything works fine under WSRV2008 X64. Even the updater runs fine now.
Also done the update all is working fine.
hope the webinterface bug is solved.
The beta update is now final release, so everybody should have this release.
2 ways to update:
1. with update button in the Source
2. by executing the setup from www.myplugwise.com (this also will update your current configuration)
2 ways to update:
@Pieter.
It cleans up the temp. logging entries (not needed anymore).
it cleans up the empty spaces in the database (after making a backup or a period).
it makes the database more efficient.
Thats a good option! I tried this before with MSAccess but no luck.
@Reinder, Rene,
Response of the plugs is with the new update sometimes very slow.
Is there a chance to speed up that again?
