plugs falling asleep
sebastiaan
Post by sebastiaan »
is anybody having this problem after updating new source ?
looks like plugs are falling asleep. they are visible but not reacting if ya ask for the stats.
restarting the source will do the trick and all the plugs are back online and reacting if asking by example the current powerusage.
greatz Sebastiaan
Reinder
Post by Reinder »
Hi Sebas,
Nice to see you are here :-)
Do you use the latest version? The latest version is V20091021.2
You can update this with the button, or download it from www.myplugwise.com
I think your reported issue is solved in this version.
I think the latest version is V20091028.0
Reinder
Post by Reinder »
No, that's only for beta users...
The latest release is mentioned above.
Verkenner
Post by Verkenner »
No Reinder.
I am not de Beta-tester. I want to use proven technology.
I've got an email from Plugwise that there is an update.
Then I updated to 20091028.0
Works fine. Plugwise HS-plugin works fine too.
Best regards, Verkenner
sebastiaan
Installed the stable version V20091021.2 and the problem i had is gone. ( thanks Reinder )upgraded to the newest ( beta ) version and found out there is a little difference in the speed the plugs answers. ( minor difference )
As i have a very large net its hard to tell if this is because of the source or the distance between the plugs.
anyway.. in V20091021.2 there no problems at all.
greats sebastiaan
Return to “Plugwise Forum”
