Plugwise Source 2.1 beta, Release 20091210
I did update as well, but even after hours it doesn't appear that all historic data has been updated.
For instance I'm missing all the historic data on my router for the last week or so. (and yes, it is online, it also did submit its usage data for the most recent hour)
- Starting Member
@YJB
I assume you made a backup before upgrading. if ya put back the backup do you still miss that data ?
For me upgrading worked just simple and smooth and all my data is there like before.
Greatz Sebastiaan
Greatz Sebastiaan
Thanks Sebastiaan!
I did already restore a backup without any success. Done it again (using a version that was a month old), and now it seems to catch-up.
I'm not sure if this was ever adressed before, but it turns out that the "dual-meter" calculation does not take into account that the weekend-days (as well as some holidays) are also using the "dal-tarief". Would appreciate if this is going to be adressed!
- Starting Member
Can some one send me the beta newest plugwise program to?
Thnxs
Evert
Thnxs
Evert
If you did not signup for the beta program you cannot activate the beta with your current license. If you did sign up, just select upgrade in the Source.
new beta available..just installing
Plugwise Source 2.1 beta, Release 20091209
Fixed:
- #446 Crash when trying to add a module while Circle+ is offline
- #460 PTE: Substring() does not function correcly when using single parameter.
- #463 Missing logdata of hours during which Source was running
- #467 Newly added appliance does not show up in reports screen until restart
- #489 PTE: Crash when using odd number of quotes in expression
- #496 Changing a tarif affects history of other tariff types.
Fixed:
@ Rene,
Just replaced the new xmlfile in the plugwisedir and the on/offline stays a problem after a refresh it's gone.
Ruud
Ruud
@Ruud: I do not understand what you mean.
@Rene
I have placed "(200912616235_)statistics.txt" in the C:\Program Files\Plugwise\Plugwise Source\www\statistics.xml. But i stil got problem the status on/off (icon in hsstatus) disapear after a refresh.
Ruud
Ruud
What version of the source are you using? Can look at the html source of the page and see what is defined as the status string for the Plugwise devices?
I'm using v20091205.08
Ruud
Ruud
Strange! Is someone else having these problems?
@Ruud: Can post the html code of the status string?
To all beta users, please update to the latest beta!
My problem is solved, copied de old statistics.xml
But with te new version source, the copy action is no longer needed.
Ruud
Ruud
Last night I updated to the latest beta, this morning the Source crashed with the following popup:
