Plugwise Source 2.1 beta, Release 20091210
** topic closed, new release update: http://www.domoticaforum.eu/viewtopic.php?f=39&t=4142
**topic changed, because of new release (all comments fixed)
Fixed:
- #463 Reopened: Missing logdata
Known issues:
- Manuals need updating
Notes:
- Because of changes in data validation, the usage history (log) is reacquired from the modules for all the current appliances. This will take some time.
Plugwise Source 2.1 beta, Release 20091209
Fixed:
- #446 Crash when trying to add a module while Circle+ is offline
- #460 PTE: Substring() does not function correcly when using single parameter.
- #463 Missing logdata
- #467 Newly added appliance does not show up in reports screen until restart
- #489 PTE: Crash when using odd number of quotes in expression
- #496 Changing a tarif affects history of other tariff types.
Plugwise Source 2.1 beta, Release 20091205
Fixed:
- #451 No status indications in appliance icons
- #452 Crash with 'Index...' message on startup or when resetting appliance totals
- #453 Crash when sending broadcast groups
- #454 Crash when deleting module in Appliances
Known issues:
Plugwise Source 2.1 beta, Release 20091204
First public beta release
Most noticeable changes since version 2.0:
- Appliance can be marked as energy producing (solar panels, wind turbines etc.)
- Better performance when handling multiple networks with hundreds of modules.
- Support for version 2 firmware
- Support for Switch.
- New driver for Stick (WHQL certified, including Windows 7 64bit)
- PTE: Many addition, see PDF in www/doc
Fixed:
Known issues:
Notes:
Fixed:
Fixed:
Known issues:
WARNING:
They made some changes in the web server interface, resulting in wrong results in the Homeseer plugin. I will provide more details later.
Some first information:
- The Source is no longer indicating the status of a device (on, off, offline) via the type of icon, not in the Source and not in the webserver. The plugin was using the name of the icon to determine the actual state of the device because the state information returned by default by the source only indicates off or on and not unknown or offline.
This is solved right away, update will come soon (within a day).
Plugwise should be so happy with the testing activities [:)]
On the other hand fixes are very rapidly done by Plugwise, great!
@Reinder: can you confirm this as well, is this function coming back or a well taken decision?
@Reinder @Rene,
Thanks for the update.
What / When will the new firmware be available, what is new in this?
My biggest problem is the performance switch time is between 0,1 - 5 seconds
I hope that this part is also optimized.
How about the Firmware update? When is that coming?
Ruud
Ruud
@ Rene, issues solved regarding the webserver/HomeSeer plugin?
firmware update planned before the end of this year...for beta users in a week??
Depending of the amount and kind feedback of Source 2.1 beta.
No comments about the Plugwise Source 2.1 beta, Release 20091205??
The right icons are displayed, however the statistics.xml file, I supplied as part of the plugin and that has to be installed in the Plugwise Source directory needs to be modified. The webserver Substring function behaves differently in this version of the Source. Where previously the maximum length parameter was optional (as also according to the manual), in this version you need to specify a maximum length. When the maximum length is omitted, the specified parameter is interpreted as the number of characters to copy till the end.
Example:
Previous version:
$str="router_on"
$str.Substring($str.LastIndexOf("_")+1) => this results in 'on'
This version:
$str="router_on"
$str.Substring($str.LastIndexOf("_")+1) => this results in 'uter_on'
The Powerstate attribute of the appliance method now also seems to return offline and unknown, meaning the construction I used is no longer required.
I attached a modified version of statistics.xml that can be used with this version of the Source.
Statistics.xml: uploaded/rklootwijk/200912616235_statistics.txt
Note: Rename the extension of this file to .xml, .xml as extension is not allowed for uploading.
Example:
Previous version:
$str="router_on"
This version:
$str="router_on"
Just upgrade my plugwise to this beta version and replaced my statistics.xml with the new one. (Thanks Rene)
Update wend smooth and quick, everything is running well including the homeseer connection.
- Starting Member
Thanks for the XML
after upgrading everything works ( faster )
Homeseer works great with new xml
greatz Sebastiaan
greatz Sebastiaan
Sebastiaan, what part is faster?
I think he mentioned that the whole system works smoother/faster.
Modules go online faster, and switch faster.
- Starting Member
Look at my other topic.
I have a totaly updated source / firmware / stretchlight now.
Problems before : slow contact / status not as it should be / lights didnt turn on on corect time etc etc.
All these things are SOLVED.. i even can switch my plugs that are on a distance of over 30 metres.( beter zigbeePro stack )
Plugs show in source after 15 seconds ( all online ) took minutes even hours before.
Homeseer wasnt working..but happely i saw the new xml so thats working again.
I had a nice weekend updating..thanks to Reinder it was all very relaxed. hope ya all think the same in a few.
database is defnitly faster as before and also smaller.
Greatz Sebastiaan
Greatz Sebastiaan
Thanks,
All sounds good.
Just updated to beta 2.1
All sounds good.
