**post changed because of a new release**
Plugwise Source 2.1 RC4, Release 20091217
Fixed:
- #558 If update message is ignored, no exclamation marc is shown in the update button
- #550 OTA: Modules of appliances with 'Temporarily not in network' set, are not ignored
Changed:
- Reports: Pressing Shift while clicking Refresh will notify user whether there is any retrievable missing data
Known issues:
- Manuals need updating
Notes:
- Because of changes in data validation, the usage history (log) is reacquired from the modules for all the current appliances. This will take some time.
- If you're still having unexplainable holes in the graphs of one ore more appliances do the following. In the Reports screen, select the appliance, click the refresh button while holding down the Shift key and then wait for a few minutes.
Plugwise Source 2.1 RC3, Release 20091215
Fixed:
- #542 OTA: Buffer of Circle+ not erased after update
- #541 Default start and end date for tariff are the same and in the past
- #538 On opening Schedules screen, the schedule of the current item is not shown
Plugwise Source 2.1 RC2, Release 20091214
Fixed:
- #522 1 of every 4 hour missing in graph
- #363 Crash: unexpected disconnect of SLP
- #528 Crash: 'Unallowed type change' exception when adding new module
Plugwise Source 2.1 RC1, Release 20091212
First release candidate
Fixed:
- #486 Crash: Old schedule with standby values <4
- #501 English translation seems broken
- #471 Savings calculations for schedules are wrong
Plugwise Source 2.1 beta, Release 20091210
Fixed:
- #463 Reopened: Missing logdata
Plugwise Source 2.1 beta, Release 20091209
Fixed:
- #446 Crash when trying to add a module while Circle+ is offline
- #460 PTE: Substring() does not function correcly when using single parameter.
- #463 Missing logdata
- #467 Newly added appliance does not show up in reports screen until restart
- #489 PTE: Crash when using odd number of quotes in expression
- #496 Changing a tarif affects history of other tariff types.
Plugwise Source 2.1 beta, Release 20091205
Fixed:
- #451 No status indications in appliance icons
- #452 Crash with 'Index...' message on startup or when resetting appliance totals
- #453 Crash when sending broadcast groups
- #454 Crash when deleting module in Appliances
Known issues:
Plugwise Source 2.1 beta, Release 20091204
First public beta release
Most noticeable changes since version 2.0:
- Appliance can be marked as energy producing (solar panels, wind turbines etc.)
- Better performance when handling multiple networks with hundreds of modules.
- Support for version 2 firmware
- Support for Switch.
- New driver for Stick (WHQL certified, including Windows 7 64bit)
- PTE: Many addition, see PDF in www/doc
Please report any bugs to
helpdesk@plugwise.com
Include the version number of your Source application in your report.
You can find it in the bottom right of the blue title bar.
ReleaseCandidate Plugwise Source2.1 available for beta users
Re: ReleaseCandidate Plugwise Source2.1 available for beta users
all working perfect for me. Did not found any bugs (reported in previous beta releases) anymore.
Also the 'trick' of missing data repair works perfect. Just (in Reports) hold the shift button and click on refresh.
I've updated and forced the retrieval of "missing" data. Looks like that is ok
The weekend inconsistency seems to be solved as well. I'm saying seems, since it appeared to be fixed in the previous build as well, but during the weekend it failed again for the "current" weekend. I'll monitor this over the weekend.
What I'm still missing is a good status indication. Plugwise never tells me that it is still working on retrieving data. For instance for some plugs it shows 0 utilization and 15 minutes later it shows the real utilization. I know that it was still working on fetching data, but it would have been much better if plugwise provides meaningfull back and states in these kind of cases "no data available"
- Advanced Member
I'm working with the V20091102.18. This one works fine for me.
I still missing the difference between incoming and outgoing energy.
The software says: There is no newer update.
BR Wim
BR Wim
@Wim.
I think that you are not a beta user... are you?
@yjb
Changed:
.....that looks like Plugwise has noticed your comment, and changed it right away
Changed:
Hmmm, no reported bugs yet??
That sounds hopeful.
I am very happy with this version. Works very stable (even unplugging the stick (of windows go to sleep) en plug stick back in again, en Source keep on working), continuously logging, much better webserver, Solarpanels are supported (produced power!).
Reinder,Reinder wrote:@yjb
I didn't see the message that it was retrieving extra data, might have missed that.
In any case I think that my comment still holds value:
Also, I feel that the update process has a kind of "messy" appearance: Windows (like the window that is doing the precheck and checks if all the plugs are online) are closing "suddenly" and then the upgrade process starts. In the end it works out fine, but initially it looks like things are going wrong. Maybe not an issue for the savy computer users, but very confusing for an average computer user (unless you are saying that the product is not aimed at the average consumer).
