When installing the new firmware, I run into the following problem: wizard step "activate and rebuild" shows the message linking to circle+, but it remains in this state for hours on end. Can anyone tell me what might cause hits or how llong it should take? When i give up and reboot the system, my plugs are no longer seen by the stick and I have to reset the circle+. The firmware update then starts all over again with the same results. if I don't do the update, I can see my power usage history, but I can get no actual results from the plugs anymore as they remain in grey with the question mark next to them. Any help/advice would be really welcome.
Update 25/12
I managed after a few retries to get all but two modules updated, those two modules are no longer recognised by the network and I can't contact them anymore either. occasionaly, they turn up in the installation wizard, but no data is recovered from them, nor can their status be seen. I never did manage to get past the activate and rebuild step though.
Plugwise firmware upgrade probleem: linking to circle+
- Starting Member
Post by Kristofgss »
- Image1.jpg (65.69 KiB) Viewed 1922 times
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
