New beta Plugwise Source 2.15 Beta 20100325 (release candida
Reinder
Re: New beta Plugwise Source 2.15 Beta 20100319 (RelC) available
Post by Reinder »
Today, a new beta Source version Plugwise Source 2.15 Beta 20100319.1 is released.
It's a minor update of beta version 2.15 with some extra bonus webserver features.
RdP
Post by RdP »
I didn't had any hope, but installed this latest beta but the Plugwise source still won't work and I went back to version 2.14 and all is working well again.
The Plugwise server is still running without any problem and the new web interface is becoming more and more mature.
But back to my problem. There must be a difference between 2.14 and 2.15 in the communication section of the source and also between the source and the server in 2.15.
I hope the problem is solved soon, so I can create new schema's with the solved standby issue.
Thanks,
DLT
Post by DLT »
After installing 2.15Beta source actually notified me that one of the Schema differ between source and a module.
Then asked me to upload the Schema again. Now my schema with low power limit switches like it should.
Nice job..
Reinder
Re: New beta Plugwise Source 2.15 Beta 20100325 (release candida
Post by Reinder »
A final beta (release candidate) is available:
Plugwise Source 2.15 Beta 20100325 (release candidate)
RdP
Post by RdP »
Reinder wrote:A final beta (release candidate) is available:
I still have the same problem !!! So, I find it strange that this is a release candidate. I reported it several times now, in this forum and also directly to Plugwise, but had no proper responses or request for additional info at all.
Again when I revert back to 2.14 everything is working normal again, so there must be something different in the code which causes this problem and despite the fact that I'm the only beta tester experiencing, you can expect that more (non beta) users will have this problem after this version is released.
/Rien
No problems here. The charts in the web interface are a very nice addition.
Bastiaan
Post by Bastiaan »
Everything ok here too and I agree with Rene, the webpages look much better.
RdP
Post by RdP »
I have a spare stick...
Does anyone of you know what will happen if I use this stick instead of the one I use now ?? Am I loosing my current configuration ??
May be this solves my problem with the new beta ....
/Rien
Verkenner
Post by Verkenner »
Everything seems oke here.
Nice webpages (but needs a little attention e.g. the possition of the icons above).
Verkenner
Best regards, Verkenner
Return to “Plugwise Forum”
