New Release Source 2.15 now available!
RdP
Re: New Release Source 2.15 now available!
Post by RdP »
I will do the upgrade tomorrow morning, and let you know the outcome
Do you have the release notes of this new version ??
/RdP
Couple of small things, you get automatic a word doc pop up, I did not save it :(
Verkenner
New Release Source 2.16b now available!
Post by Verkenner »
For betatesters. New Release Source 2.16b is available now!
Works fine here.
Watch the webserver !
Rgrds, Verkenner
Best regards, Verkenner
Bastiaan
Post by Bastiaan »
16b running fine for a while now and its nice to run it as a server without the GIU
Hi Bastiaan
Are you running the new firmware 2.19 also?
Bastiaan
Post by Bastiaan »
I don't see a firmware number on the appliances, only a firmware date: 2009-09-08
Source build no ends at 717.2 (still very hard to read.....)
Running the updater doesn't find anything new.
RdP
Post by RdP »
I did the upgrade....
It is a beta release, so only for beta testers. It says 2.16beta (20100717.2) as the version number....
It's running fine here, but I really don't know what has changed....
THe HS plugin, seems to be running fine as well with this update.
So Pieter, it strange you got version 2.19 and new firmware. Firmware was always referred with a date and not with a version numbers. Like " 2009-09-08" is my current firmware of the plug's.
How did you get this update ? It's probably a good idea to contact plugwise directly.
I did had contact with plugwise and the matter is resolved.
I was/am an early adapter of Plugwise and a lot of my circles where really old and beta These circles where not delivered to customers.
And there was a firmware 2.29 for Beta users but its temporary offline now just to be sure.
Plugwise is doing some investigation just to be sure and then I guess the firmware will be on-line again.
I'm now running the new firmware on 30 Circles together with source 2.16 Beta and all is going well till now.
Keep u posted on this.
I will create a new topic on the new plugwise webserver, Bastiaan triggerd us about it. You can even make graphs in your own website colors.
Source Release:
Latest Plugwise Source Release: 20100328.0 version 2.15
Firmware Release:
Latest firmware Release is:
Stick, C+ and C: 2009-09-08 version 2.27 (R27)
Switch  : 2010-01-16
Beta **only in Beta 3 not for use extern**:
Source Beta: (20100601.2) version 2.16 beta: download
Firmware Beta (Stick, C+, C and Switch) 2010-04-27 version: 2.29 (R29)
Hardware:
Switch test versions can be purchased (limited). Not officially released yet.
Return to “Plugwise Forum”
