plugwiseServer.exe
pvgent
plugwiseServer.exe
Post by pvgent »
Anyone experience with PlugwiseServer.exe it's supposed to be same as the Source but without the user interface.
I tried to start it but i get a message, ' index and length must refer to a location within the string' and then it stops.
I'm have Server 20100328.0 and the Source is also 20100328.0
I also tried to create an ini-file as described in the Plugwise_Source_Template_Engine.pdf, but it didn't make a difference.
It's would be nice if it worked because you can tell it to run a script at an certain interval, this would be nice to create master/slave actions.
Script check's if powerusage of a circle is above an certain value and then switches on another circle and if it's below an certain value it switches another circle off.
Return to “Plugwise Forum”
