I've been using Plugwise with Linux now for some years and it has worked great thanks to some persons on these forums for reverse engineering the protocol. But yesterday I was going to upgrade my kernel to 2.6.38 from 2.6.34 and after that there has been nothing but problems. So I reverted to the old kernel. However, now I'm asking to see if anyone else has tried 2.6.38 with Plugwise and how did that go?
Wondering if it could be a driver issue. I also has an USB serial adapter and that one also seems to become messy after I start to communicate with the stick.
Linux and stick issues
Re: Linux and stick issues
I'm using plugwise on a Ubuntu 10.4 LTS with backported 2.6.38-8 kernel and have no problems using the plugwise modules using Domotiga.
I do however use an udev-rule to pin the stick to a fixed adress so it doesn't get changed by one of the other FTDI-devices on the same server.
Okay, thanks for an answer.j.hoekstra wrote:I'm using plugwise on a Ubuntu 10.4 LTS with backported 2.6.38-8 kernel and have no problems using the plugwise modules using Domotiga.
My system is Gentoo and self compiled kernel. Me too uses custom made udev rules for linking the stick to fixed address. However, the other ttyUSB is a pl2303 driver so maybe I need remove it and try again. Bulk taped inside so need to pop the hood when I get some time for it
