Scan & Sense discount and new Plugwise source 2.20
Akatar
Re: Scan & Sense discount and new Plugwise source 2.20
Post by Akatar »
another bug?
when i choose:
instellingen-->apparaten-->dubbel click sense
the program crashes
T-Rex
Post by T-Rex »
T-Rex wrote:After applying the update earlier this evening my complete WIndows start folder is wiped clean. Everything is gone. After reading your post I downloaded the bèta of the link above and started it. Now only the plugwise folder is there, all my other start menu items are still gone.
I used System Restore to get the system back to an earlier time today and luckily my start menu is back. I'm somewhat "afraid" to try running or updating Source now just before going to bed, with some bad luck I have to stay up late to repair my Windows again.
Next try will be tomorrow evening, hopefully it is safe then to update.
Reinder
Post by Reinder »
You can do the update again by using the setup exe. It is fixed now.
@alkatar, please send a Plugwise to the helpdesk. I think it's a user specific problem. They can check/fix your database.
T-Rex
Post by T-Rex »
Indeed, the second update worked fine. Thanks.
Akatar
Post by Akatar »
Reinder wrote:You can do the update again by using the setup exe. It is fixed now.
nope,
it's a bug in the source.
will be fixed in the next release
Return to “Plugwise Forum”
